Hi
Since synchronization via WebDAV always leads to conflicts for me, I would rather use a more modern protocol such as EteSync.
Will WebDAV in Nextcloud be replaced by a better protocol in the foreseeable future?
Hi
Hello and welcome to the community help forum!
A “conflict” arises when a file has been changed in two different locations independently. This is a technology agnostic fact which can happen per definition with each protocol.
Not that i can speak for Nextcloud Inc., but i assume it is pretty safe to say: No. It is very very unlikely that WebDAV
will be replaced by another protocol in the foreseeable future.
Since I personally did not experience any conflicts (except the above situation occurs, of course), i am wonderint whether you setup is configured properly and you are not facing any environment related issues. WebDAV
is actually a quite robust and reliable protocol which is supported by many large projects and well-proved
