is anyone here, who syncs a Synolgy Disk Station with a NextCloud? Which way do you do that? I started with “Cloud Sync” and a WebDAV-connection and it works, but not very well. Synolgy is aware of the issues, but doesn’t support WebDAV, they consider it as workaround. So, is there a better way?
