[details=“Support intro”]
Nextcloud version (eg, 18.0.2): 18.0.2.2
Operating system and version (eg, Ubuntu 20.04): "Ubuntu 18.04.4
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.29
PHP version (eg, 7.1): 7.2.24
When updating nextcloud I get the following error. I am using RDS (Aurora Mysql) as a backing Database.
/var/www/html# sudo -u www-data ./occ upgrade --no-interaction -vvv
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
2020-11-15T10:14:28+00:00 Set log level to debug
2020-11-15T10:14:28+00:00 Repair step: Repair MySQL collation
2020-11-15T10:14:28+00:00 Repair info: All tables already have the correct collation -> nothing to do
2020-11-15T10:14:28+00:00 Repair step: Repair SQLite autoincrement
2020-11-15T10:14:28+00:00 Repair step: Copy data from accounts table when migrating from ownCloud
2020-11-15T10:14:29+00:00 Repair step: Drop account terms table when migrating from ownCloud
2020-11-15T10:14:29+00:00 Updating database schema
2020-11-15T10:14:30+00:00 Updated database
2020-11-15T10:14:30+00:00 Updating <mail> ...
2020-11-15T10:14:31+00:00 Repair step: Purify and migrate collected mail addresses
2020-11-15T10:14:31+00:00 Purify and migrate collected mail addresses
Done
0/0 [>-] 0%2020-11-15T10:14:31+00:00
2020-11-15T10:14:31+00:00 Repair step: Insert sync background job for all accounts
2020-11-15T10:14:31+00:00 BadFunctionCallException: showSubscribedOnly is not a valid attribute
2020-11-15T10:14:31+00:00 Update failed
2020-11-15T10:14:31+00:00 Maintenance mode is kept active
2020-11-15T10:14:31+00:00 Reset log level
'instanceid' => '$XYZ',
'passwordsalt' => '$XYZ',
'secret' => '$XYZ',
0 => 'xyz.elb.amazonaws.com',
'datadirectory' => '/ebs',
'version' => '18.0.2.2',
'overwrite.cli.url' => 'https://mycloud',
'dbname' => 'nc',
'dbhost' => 'xyz.rds.amazonaws.com',
'dbuser' => '$XYZ',
'dbpassword' => '$XYZ',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_domain' => '$XYZ.de',
'mail_smtpauth' => 1,
'mail_smtphost' => '$XYZ',
'mail_smtpport' => '587',
'mail_smtpname' => '$XYZ',
'mail_smtppassword' => '$XYZ',
'theme' => '',
'loglevel' => 2,
'maintenance' => true,
