BadFunctionCallException propertytype is not a valid attribute
    • 31.0.7
    • FreeBSD 13.1-RELEASE-p9
    • Caddy v2.6.4 h1
    • pfSense HAProxy
    • 8.2.28
    • yes
    • after Nextcloud upgrade
    • FreeBSD Jail
    • replace me
Log spammed with BadFunctionCallException propertytype is not a valid attribute
  1. Upgrade to recent Nextcloud
[no app in context] Error: propertytype is not a valid attribute
	PUT /ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json
	from 192.168.1.1 by Chad at Jul 14, 2025, 10:07:21 AM
{“reqId”:“WrJYZqPuYcwCo2jmBRLu”,“level”:3,“time”:“2025-07-14T10:08:19-05:00”,“remoteAddr”:“192.168.1.1”,“user”:“Chad”,“app”:“no app in context”,“method”:“PUT”,“url”:“/ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json”,“message”:“propertytype is not a valid attribute”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/138.0.0.0 Safari/537.36 Edg/138.0.0.0”,“version”:“31.0.7.1”,“exception”:{“Exception”:“BadFunctionCallException”,“Message”:“propertytype is not a valid attribute”,“Code”:0,“Trace”:[{“file”:“/usr/local/www/nextcloud/lib/public/AppFramework/Db/Entity.php”,“line”:59,“function”:“setter”,“class”:“OCP\AppFramework\Db\Entity”,“type”:“->”,“args”:[“propertytype”,[1]]},{“file”:“/usr/local/www/nextcloud/lib/public/AppFramework/Db/QBMapper.php”,“line”:315,“function”:“fromRow”,“class”:“OCP\AppFramework\Db\Entity”,“type”:“::”,“args”:[{“id”:64,“propertyname”:“{http://owncloud.org/ns}calendar-enabled”,“propertyvalue”:“1”,“propertytype”:1,“userid”:“Chad”,“propertypath”:“calendars/Chad/personal”,“valuetype”:1}]},{“file”:“/usr/local/www/nextcloud/lib/public/AppFramework/Db/QBMapper.php”,“line”:333,“function”:“mapRowToEntity”,“class”:“OCP\AppFramework\Db\QBMapper”,“type”:“->”,“args”:[{“id”:64,“propertyname”:“{http://owncloud.org/ns}calendar-enabled”,“propertyvalue”:“1”,“propertytype”:1,“userid”:“Chad”,“propertypath”:“calendars/Chad/personal”,“valuetype”:1}]},{“file”:“/usr/local/www/nextcloud/apps/dav/lib/Db/PropertyMapper.php”,“line”:52,“function”:“findEntities”,“class”:“OCP\AppFramework\Db\QBMapper”,“type”:“->”,“args”:[{“class”:“OC\DB\QueryBuilder\QueryBuilder”}]},{“file”:“/usr/local/www/nextcloud/apps/dav/lib/CalDAV/CalendarProvider.php”,“line”:56,“function”:“findPropertiesByPath”,“class”:“OCA\DAV\Db\PropertyMapper”,“type”:“->”,“args”:[“Chad”,“calendars/Chad/personal”]},{“file”:“/usr/local/www/nextcloud/apps/dav/lib/CalDAV/CalendarProvider.php”,“line”:41,“function”:“getAdditionalProperties”,“class”:“OCA\DAV\CalDAV\CalendarProvider”,“type”:“->”,“args”:[“principals/users/Chad”,“personal”]},{“file”:“/usr/local/www/nextcloud/lib/private/Calendar/Manager.php”,“line”:188,“function”:“getCalendars”,“class”:“OCA\DAV\CalDAV\CalendarProvider”,“type”:“->”,“args”:[“principals/users/Chad”,]},{“function”:“OC\Calendar\{closure}”,“class”:“OC\Calendar\Manager”,“type”:“->”,“args”:[“*** sensitive parameters replaced “]},{“file”:”/usr/local/www/nextcloud/lib/private/Calendar/Manager.php",“line”:177,“function”:“array_map”,“args”:[{“class”:“Closure”},[" sensitive parameters replaced “,” sensitive parameters replaced ***”]]},{“file”:“/usr/local/www/nextcloud/apps/dav/lib/CalDAV/Status/StatusService.php”,“line”:152,“function”:“getCalendarsForPrincipal”,“class”:“OC\Calendar\Manager”,“type”:“->”,“args”:[“principals/users/Chad”]},{“file”:“/usr/local/www/nextcloud/apps/dav/lib/CalDAV/Status/StatusService.php”,“line”:56,“function”:“getCalendarEvents”,“class”:“OCA\DAV\CalDAV\Status\StatusService”,“type”:“->”,“args”:[{“class”:“OC\User\User”}]},{“file”:“/usr/local/www/nextcloud/apps/user_status/lib/Listener/UserLiveStatusListener.php”,“line”:52,“function”:“processCalendarStatus”,“class”:“OCA\DAV\CalDAV\Status\StatusService”,“type”:“->”,“args”:[“Chad”]},{“file”:“/usr/local/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php”,“line”:68,“function”:“handle”,“class”:“OCA\UserStatus\Listener\UserLiveStatusListener”,“type”:“->”,“args”:[{“class”:“OCP\User\Events\UserLiveStatusEvent”}]},{“file”:“/usr/local/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php”,“line”:220,“function”:“__invoke”,“class”:“OC\EventDispatcher\ServiceEventListener”,“type”:“->”,“args”:[{“class”:“OCP\User\Events\UserLiveStatusEvent”},“OCP\User\Events\UserLiveStatusEvent”,{“class”:“Symfony\Component\EventDispatcher\EventDispatcher”}]},{“file”:“/usr/local/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php”,“line”:56,“function”:“callListeners”,“class”:“Symfony\Component\EventDispatcher\EventDispatcher”,“type”:“->”,“args”:[[{“class”:“Closure”}],“OCP\User\Events\UserLiveStatusEvent”,{“class”:“OCP\User\Events\UserLiveStatusEvent”}]},{“file”:“/usr/local/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php”,“line”:67,“function”:“dispatch”,“class”:“Symfony\Component\EventDispatcher\EventDispatcher”,“type”:“->”,“args”:[{“class”:“OCP\User\Events\UserLiveStatusEvent”},“OCP\User\Events\UserLiveStatusEvent”]},{“file”:“/usr/local/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php”,“line”:79,“function”:“dispatch”,“class”:“OC\EventDispatcher\EventDispatcher”,“type”:“->”,“args”:[“OCP\User\Events\UserLiveStatusEvent”,{“class”:“OCP\User\Events\UserLiveStatusEvent”}]},{“file”:“/usr/local/www/nextcloud/apps/user_status/lib/Controller/HeartbeatController.php”,“line”:71,“function”:“dispatchTyped”,“class”:“OC\EventDispatcher\EventDispatcher”,“type”:“->”,“args”:[{“class”:“OCP\User\Events\UserLiveStatusEvent”}]},{“file”:“/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php”,“line”:200,“function”:“heartbeat”,“class”:“OCA\UserStatus\Controller\HeartbeatController”,“type”:“->”,“args”:[“online”]},{“file”:“/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php”,“line”:114,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”,“args”:[{“class”:“OCA\UserStatus\Controller\HeartbeatController”},“heartbeat”]},{“file”:“/usr/local/www/nextcloud/lib/private/AppFramework/App.php”,“line”:161,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”,“args”:[{“class”:“OCA\UserStatus\Controller\HeartbeatController”},“heartbeat”]},{“file”:“/usr/local/www/nextcloud/lib/private/Route/Router.php”,“line”:315,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”,“args”:[“OCA\UserStatus\Controller\HeartbeatController”,“heartbeat”,{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{“_route”:“ocs.user_status.heartbeat.heartbeat”}]},{“file”:“/usr/local/www/nextcloud/ocs/v1.php”,“line”:49,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”,“args”:[“/ocsapp/apps/user_status/api/v1/heartbeat”]},{“file”:“/usr/local/www/nextcloud/ocs/v2.php”,“line”:7,“args”:[“/usr/local/www/nextcloud/ocs/v1.php”],“function”:“require_once”}],“File”:“/usr/local/www/nextcloud/lib/public/AppFramework/Db/Entity.php”,“Line”:95,“message”:“propertytype is not a valid attribute”,“exception”:,“CustomMessage”:“propertytype is not a valid attribute”},“id”:“68751d6a0a806”}
            "bisek.photography",
            "www.bisek.photography",
            "192.168.1.13",
            "nextcloud.bisek.photography"
        "dbtype": "mysql",
        "version": "31.0.7.1",
        "dbport": "",
        "mysql.utf8mb4": true,
        "logtimezone": "America\/Chicago",
        "log_type": "file",
        "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
        "loglevel": 0,
        "logrotate_size": "104847600",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauthtype": "PLAIN",
        "mail_smtpauth": 1,
        "mail_smtpport": "465",
        "mail_smtpsecure": "ssl",
        "redis": {
            "port": 0
        "htaccess.RewriteBase": "\/",
        "theme": "",
        "default_phone_region": "US",
        "app_install_overwrite": [
            "files_linkeditor",
            "cookbook"
        "forwarded_for_headers": [
            "HTTP_X_FORWARDED_FOR"
        "overwritehost": "bisek.photography",
        "overwrite.cli.url": "https:\/\/bisek.photography",
        "overwriteprotocol": "https",
        "maintenance_window_start": 7
  • app_api: 5.0.2
  • calendar: 5.3.5
  • circles: 31.0.0
  • comments: 1.21.0
  • contacts: 7.1.5
  • contactsinteraction: 1.12.0
  • cookbook: 0.11.3
  • dashboard: 7.11.0
  • dav: 1.33.0
  • federation: 1.21.0
  • files: 2.3.1
  • files_downloadlimit: 4.0.0
  • files_external: 1.23.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • firstrunwizard: 4.0.0
  • forms: 5.1.2
  • guests: 4.3.0
  • integration_google: 4.0.0
  • logreader: 4.0.0
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • password_policy: 3.0.0
  • photos: 4.0.0
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • workflowengine: 2.13.0
  • activity: 4.0.0 (installed 2.5.2)
  • admin_audit: 1.21.0
  • bruteforcesettings: 4.0.0 (installed 2.0.1)
  • encryption: 2.19.0
  • files_pdfviewer: 4.0.0 (installed 0.11.1)
  • files_rightclick: 0.15.1 (installed 1.6.0)
  • groupfolders: 19.1.1 (installed 19.1.1)
  • integration_homeassistant: 0.0.6 (installed 0.0.6)
  • suspicious_login: 9.0.1
  • user_ldap: 1.22.0 (installed 0.9.1)
For future me…
select * from information_schema.columns where column_name = 'propertytype';
From list of tables with column name propertytype
describe oc_dav_properties;
alter table `oc_dav_properties` drop `propertytype`;
