Autostart on client does not auto start on fedora
ome or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. :heart:
  • Nextcloud Server version:
    • Nextcloud 33.0.2
    • #1 SMP PREEMPT Debian 1:6.12.75-1+rpt1~bookworm (2026-03-11)
  • Web server and version:
    • Server version: Apache/2.4.66 (Debian)
  • Reverse proxy and version:
    • nginx version: openresty/1.27.1.2
  • PHP version:
    • PHP 8.4.19 (cli) (built: Mar 16 2026 22:27:46) (NTS)
    • yes
    • recently
    • OMV Container
Summary of the issues you are facing:
Specifiying autostart on the settings of the client does not autostart it:
  1. Enable autostart
  2. Logoff and Logon
{"reqId":"SoI8ugD6gViW4ojR5ky8","level":3,"time":"2026-04-03T07:25:48+00:00","remoteAddr":"83.97.85.45","user":"johannes","app":"onlyoffice","method":"GET","url":"/apps/files_sharing/publicpreview/ZpkeKSZcn849Wwx?file=%2FOP-1+Manual+1.2+%28EN%29.pdf&x=32&y=32&mimeFallback=true&v=8b425e&a=0","scriptName":"/index.php","message":"Failed to download thumbnail","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:149.0) Gecko/20100101 Firefox/149.0","version":"33.0.2.2","exception":{"Exception":"GuzzleHttp\\Exception\\ConnectException","Message":"cURL error 28: Connection timed out after 60002 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://cloud.kingma.ch/cache/files/data/conv_thumb_3499714562_1025/output.jpg/thumb_3499714562.jpg?md5=4Mpfu5N_DVKplh8-FHKikQ&expires=1775201989&shardkey=863781301&filename=thumb_3499714562.jpg","Code":0,"Trace":[{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":207,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":159,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":[{"__class__":"GuzzleHttp\\Handler\\CurlHandler"},"*** sensitive parameters replaced ***",{"__class__":"GuzzleHttp\\Handler\\CurlFactory"}]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":[{"__class__":"GuzzleHttp\\Handler\\CurlHandler"},"*** sensitive parameters replaced ***",{"__class__":"GuzzleHttp\\Handler\\CurlFactory"}]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":142,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Http/Client/DnsPinMiddleware.php","line":110,"function":"{closure:{closure:GuzzleHttp\\Middleware::tap():137}:138}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"{closure:{closure:OC\\Http\\Client\\DnsPinMiddleware::addDnsPinning():104}:105}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"{closure:{closure:GuzzleHttp\\Middleware::cookies():28}:29}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":66,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"{closure:{closure:GuzzleHttp\\Middleware::httpErrors():60}:61}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":333,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":169,"function":"transfer","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Http/Client/Client.php","line":219,"function":"request","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***",{"verify":"/var/www/html/resources/config/ca-bundle.crt","timeout":60,"version":"2.0","curl":{"84":4},"nextcloud":{"allow_local_address":true},"0":"And 2 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/custom_apps/onlyoffice/lib/DocumentService.php","line":410,"function":"get","class":"OC\\Http\\Client\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/custom_apps/onlyoffice/lib/Preview.php","line":273,"function":"request","class":"OCA\\Onlyoffice\\DocumentService","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Preview/GeneratorHelper.php","line":25,"function":"getThumbnail","class":"OCA\\Onlyoffice\\Preview","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},4096,4096]},{"file":"/var/www/html/lib/private/Preview/Generator.php","line":381,"function":"getThumbnail","class":"OC\\Preview\\GeneratorHelper","type":"->","args":[{"__class__":"OCA\\Onlyoffice\\Preview"},{"__class__":"OC\\Files\\Node\\File"},4096,4096]},{"file":"/var/www/html/lib/private/Preview/Generator.php","line":335,"function":"generateProviderPreview","class":"OC\\Preview\\Generator","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},4096,4096,false,true,"application/pdf",null]},{"file":"/var/www/html/lib/private/Preview/Generator.php","line":126,"function":"getMaxPreview","class":"OC\\Preview\\Generator","type":"->","args":[[],{"__class__":"OC\\Files\\Node\\File"},"application/pdf",null]},{"file":"/var/www/html/lib/private/Preview/Generator.php","line":94,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},[{"width":32,"height":32,"crop":true,"mode":"fill"}],"application/pdf",true]},{"file":"/var/www/html/lib/private/PreviewManager.php","line":166,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},32,32,true,"fill",null,true]},{"file":"/var/www/html/apps/files_sharing/lib/Controller/PublicPreviewController.php","line":129,"function":"getPreview","class":"OC\\PreviewManager","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},32,32,true]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":205,"function":"getPreview","class":"OCA\\Files_Sharing\\Controller\\PublicPreviewController","type":"->","args":["ZpkeKSZcn849Wwx",{"__class__":"OC\\Files\\Node\\File"},32,32,false,true]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Files_Sharing\\Controller\\PublicPreviewController"},"getPreview"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Files_Sharing\\Controller\\PublicPreviewController"},"getPreview"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Files_Sharing\\Controller\\PublicPreviewController","getPreview",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"files_sharing.publicpreview.getpreview","token":"ZpkeKSZcn849Wwx"}]},{"file":"/var/www/html/lib/base.php","line":1155,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/files_sharing/publicpreview/ZpkeKSZcn849Wwx"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":277,"message":"Failed to download thumbnail","exception":"{\"class\":\"GuzzleHttp\\Exception\\ConnectException\",\"message\":\"cURL error 28: Connection timed out after 60002 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://cloud.kingma.ch/cache/files/data/conv_thumb_3499714562_1025/output.jpg/thumb_3499714562.jpg?md5=4Mpfu5N_DVKplh8-FHKikQ&expires=1775201989&shardkey=863781301&filename=thumb_3499714562.jpg\",\"code\":0,\"file\":\"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php:277\",\"trace\":\"#0 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php(207): GuzzleHttp\\Handler\\CurlFactory::createRejection(Object(GuzzleHttp\\Handler\\EasyHandle), Array)\\n#1 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php(159): GuzzleHttp\\Handler\\CurlFactory::finishError(Object(GuzzleHttp\\Handler\\CurlHandler), Object(GuzzleHttp\\Handler\\EasyHandle), Object(GuzzleHttp\\Handler\\CurlFactory))\\n#2 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php(47): GuzzleHttp\\Handler\\CurlFactory::finish(Object(GuzzleHttp\\Handler\\CurlHandler), Object(GuzzleHttp\\Handler\\EasyHandle), Object(GuzzleHttp\\Handler\\CurlFactory))\\n#3 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php(142): GuzzleHttp\\Handler\\CurlHandler->__invoke(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#4 /var/www/html/lib/private/Http/Client/DnsPinMiddleware.php(110): GuzzleHttp\\Middleware::{closure:{closure:GuzzleHttp\\Middleware::tap():137}:138}(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#5 /var/www/html/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php(35): OC\\Http\\Client\\DnsPinMiddleware->{closure:{closure:OC\\Http\\Client\\DnsPinMiddleware::addDnsPinning():104}:105}(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#6 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php(31): GuzzleHttp\\PrepareBodyMiddleware->__invoke(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#7 /var/www/html/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php(71): GuzzleHttp\\Middleware::{closure:{closure:GuzzleHttp\\Middleware::cookies():28}:29}(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#8 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php(66): GuzzleHttp\\RedirectMiddleware->__invoke(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#9 /var/www/html/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php(75): GuzzleHttp\\Middleware::{closure:{closure:GuzzleHttp\\Middleware::httpErrors():60}:61}(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#10 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php(333): GuzzleHttp\\HandlerStack->__invoke(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#11 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php(169): GuzzleHttp\\Client->transfer(Object(GuzzleHttp\\Psr7\\Request), Array)\\n#12 /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php(189): GuzzleHttp\\Client->requestAsync('get', Object(GuzzleHttp\\Psr7\\Uri), Array)\\n#13 /var/www/html/lib/private/Http/Client/Client.php(219): GuzzleHttp\\Client->request('get', 'https://cloud.k...', Array)\\n#14 /var/www/html/custom_apps/onlyoffice/lib/DocumentService.php(410): OC\\Http\\Client\\Client->get('https://cloud.k...', Array)\\n#15 /var/www/html/custom_apps/onlyoffice/lib/Preview.php(273): OCA\\Onlyoffice\\DocumentService->request('https://cloud.k...')\\n#16 /var/www/html/lib/private/Preview/GeneratorHelper.php(25): OCA\\Onlyoffice\\Preview->getThumbnail(Object(OC\\Files\\Node\\File), 4096, 4096)\\n#17 /var/www/html/lib/private/Preview/Generator.php(381): OC\\Preview\\GeneratorHelper->getThumbnail(Object(OCA\\Onlyoffice\\Preview), Object(OC\\Files\\Node\\File), 4096, 4096)\\n#18 /var/www/html/lib/private/Preview/Generator.php(335): OC\\Preview\\Generator->generateProviderPreview(Object(OC\\Files\\Node\\File), 4096, 4096, false, true, 'application/pdf', NULL)\\n#19 /var/www/html/lib/private/Preview/Generator.php(126): OC\\Preview\\Generator->getMaxPreview(Array, Object(OC\\Files\\Node\\File), 'application/pdf', NULL)\\n#20 /var/www/html/lib/private/Preview/Generator.php(94): OC\\Preview\\Generator->generatePreviews(Object(OC\\Files\\Node\\File), Array, 'application/pdf', true)\\n#21 /var/www/html/lib/private/PreviewManager.php(166): OC\\Preview\\Generator->getPreview(Object(OC\\Files\\Node\\File), 32, 32, true, 'fill', NULL, true)\\n#22 /var/www/html/apps/files_sharing/lib/Controller/PublicPreviewController.php(129): OC\\PreviewManager->getPreview(Object(OC\\Files\\Node\\File), 32, 32, true)\\n#23 /var/www/html/lib/private/AppFramework/Http/Dispatcher.php(205): OCA\\Files_Sharing\\Controller\\PublicPreviewController->getPreview('ZpkeKSZcn849Wwx', Object(OC\\Files\\Node\\File), 32, 32, false, true)\\n#24 /var/www/html/lib/private/AppFramework/Http/Dispatcher.php(118): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\Files_Sharing\\Controller\\PublicPreviewController), 'getPreview')\\n#25 /var/www/html/lib/private/AppFramework/App.php(153): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Files_Sharing\\Controller\\PublicPreviewController), 'getPreview')\\n#26 /var/www/html/lib/private/Route/Router.php(321): OC\\AppFramework\\App::main('OCA\\\\Files_Shari...', 'getPreview', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\\n#27 /var/www/html/lib/base.php(1155): OC\\Route\\Router->match('/apps/files_sha...')\\n#28 /var/www/html/index.php(25): OC::handleRequest()\\n#29 {main}\"}","CustomMessage":"Failed to download thumbnail"}}
  • activity: 6.0.0
  • admin_audit: 1.23.0
  • bookmarks: 16.1.3
  • brewmemo: 0.6.0
  • bruteforcesettings: 6.0.0
  • calendar: 6.2.2
  • circles: 33.0.0
  • comments: 1.23.0
  • contacts: 8.4.3
  • contactsinteraction: 1.14.1
  • cookbook: 0.11.6
  • dashboard: 7.13.0
  • dav: 1.36.0
  • encryption: 2.21.0
  • end_to_end_encryption: 2.0.2
  • federation: 1.23.0
  • files: 2.5.0
  • files_downloadlimit: 5.1.0
  • files_external: 1.25.1
  • files_pdfviewer: 6.0.0
  • files_reminders: 1.6.0
  • files_sharing: 1.25.2
  • files_trashbin: 1.23.0
  • files_versions: 1.26.0
  • firstrunwizard: 6.0.0
  • fulltextsearch: 33.0.0
  • groupfolders: 21.0.6
  • logreader: 6.0.0
  • notes: 4.13.1
  • notifications: 6.0.0
  • oauth2: 1.21.0
  • onlyoffice: 10.0.0
  • password_policy: 5.0.0
  • photos: 6.0.0
  • privacy: 5.0.0
  • profile: 1.2.0
  • provisioning_api: 1.23.0
  • recommendations: 6.0.0
  • related_resources: 4.0.0
  • serverinfo: 5.0.0
  • settings: 1.16.0
  • sharebymail: 1.23.0
  • support: 5.0.0
  • survey_client: 5.0.0
  • suspicious_login: 11.0.0
  • systemtags: 1.23.0
  • text: 7.0.0
  • theming: 2.8.0
  • twofactor_totp: 15.0.0
  • updatenotification: 1.23.0
  • uppush: 2.4.0
  • user_status: 1.13.0
  • viewer: 6.0.0
  • weather_status: 1.13.0
  • webhook_listeners: 1.5.0
  • workflowengine: 2.15.0
  • app_api: 33.0.0 (installed 32.0.0)
  • camerarawpreviews: 0.8.8 (installed 0.8.8)
  • keeweb: 0.6.22 (installed 0.6.22)
  • richdocuments: 10.1.2 (installed 10.1.2)
  • testing: 1.23.0
  • user_ldap: 1.24.0 (installed 1.22.0)
You filed a lot of topics in the past.
And you still provide way less information.
  • wrong category
  • No version information of client version
  • No client os named
  • No client configuration
  • Wrong tags assigned
We take time to support, so spend time to file topics in good quality.
Thanks. I probably need more information on what information you need.
See me screenshots I make it a bit bigger for you
and btw I did not put any tags. sorry for that.
