My nextcloud server keeps enabling maintenance mode automatically and i have no edit the config file to turn maintenance to false
The maintenance mode was enabled ba a reason. What happened before maintenance mode did enable? - Did you update Nextcloud?
Did you take a look into nextcloud.log - depending on the system either in the nextcloud data folder or in /var/log.
Hi
Thanks for your reply
First link is apache error log
second is the nextcloud log file from the “current” folder???
any ideas?
Sorry, but I was too late to download the log files. They haved been removed.
