example
longer
example
here
Nextcloud version 3.15.0
Operating system and version Android 9
Apache or nginx version Apache
PHP version 7.4
The auto-update button is not available
All our mobiles have the same problem.
PASTE HERE
PASTE HERE
PASTE HERE
