example
longer
example
here
Nextcloud version (eg, 20.0.5): 20.0.8
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.2 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41 (Ubuntu)
PHP version (eg, 7.4): PHP 7.4.3
When logging into Nextcloud on the web interface, the server never logs out the user automatically after any period of time. Is there a way to fix this so that if I a user is inactive on the web interface the systems logs out them out after 30 minutes of inactivity?
I searched in the forums and added a few lines to the config.php file in /var/xxx/nextcloud/config, but I am not getting any positive results. I am obviously doing something wrong. These are the lines I added:
‘remember_login_cookie_lifetime’ => 1296000,
‘session_lifetime’ => 43200,
‘session_keepalive’ => false,
‘auto_logout’ => false,
What am I doing wrong? How do I fix the problem? Thanks!
- Login as either admin or user to Nexcloud web interface
- Remain inactive for any period of time
- Open web address of web interface after being inactive and instead of login page you are directed to user’s logged interface
PASTE HERE
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'nextcloud.example.com',
'datadirectory' => '/var/www/nextcloud-data/',
'version' => '20.0.8.1',
'overwrite.cli.url' => 'https://nextcloud.example.com',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:3306',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'mail_smtpmode' => 'smtp',
'mail_sendmailmode' => 'pipe',
'mail_from_address' => 'xxx',
'mail_domain' => 'example.com',
'mail_smtpauth' => 1,
'mail_smtphost' => 'localhost',
'mail_smtpport' => '1025',
'mail_smtpname' => 'xxx@example.com',
'mail_smtppassword' => 'xxx',
'mail_smtptimeout' => 30,
'remember_login_cookie_lifetime' => 1296000,
'session_lifetime' => 43200,
'session_keepalive' => false,
'auto_logout' => false,
'redis' =>
'host' => 'localhost',
'port' => 6379,
'theme' => '',
'loglevel' => 2,
PASTE HERE
