[/details]
Nextcloud version (eg, 20.0.5): 25.0.2
Operating system and version (eg, Ubuntu 20.04): 22.04.1
Apache or nginx version (eg, Apache 2.4.25): 2.4.52
PHP version (eg, 7.4): 8.1.2
After configuring SSO with SimpleSAMLphp, the SSO logins work as expected, and the attribute mappings all work. Addtionally, we’re forcing the users into a group “SSOUSERS” via the mapped attribute, and it works great. However, we have one issue. If I add an already created user (myself for example) to a different group (say the admin group), whenever that user logs in, it removes them from the admin group and overwrites all group membership with “SSOUSERS”. I’ve tried every combination of settings in the “Additional Settings” menu for group overrides, but nothing seems to prevent it. Also, the admin email receives the update that the user was ‘successfully removed from the group admin’. Anyone have a work around for this?
Y
- Setup SSO correctly w/ option to pass group membership
- Add created user to “admin” group and set “override” for autogroup
- Once user logs in, they are no longer in the admin group
No related errors in logs
'instanceid' => 'xxxxinstanceidxxxx',
'passwordsalt' => 'xxxxsaltxxxx',
'secret' => 'xxxxsecretxxxx',
0 => 'xxx.xxx.xxx',
'log_type' => 'file',
'logfile' => 'nextcloud.log',
'loglevel' => 0,
'logdateformat' => 'F d, Y H:i:s',
'default_phone_region' => 'US',
'datadirectory' => '/data/nextcloud/data',
'version' => '25.0.2.3',
'overwrite.cli.url' => 'http://xxx.xxx.xxx',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'xxxxxxxx',
'dbpassword' => 'xxxxxxxx',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'app_install_overwrite' =>
0 => 'integration_moodle',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => 'ncadmin',
'mail_domain' => 'xxx.xxx.xxx',
'mail_smtphost' => 'xxx.xxx.xxx',
'mail_smtpport' => '25',
PHP Warning: Module "imagick" is already loaded in Unknown on line 0
[Tue Jan 17 00:00:00.793803 2023] [mpm_prefork:notice] [pid 1415] AH00163: Apache/2.4.52 (Ubuntu) OpenSSL/3.0.2 configured -- resuming normal operations
[Tue Jan 17 00:00:00.793820 2023] [core:notice] [pid 1415] AH00094: Command line: '/usr/sbin/apache2'
PASTE HERE
