I have a problem with the “Retention App”, when tagging folders and files with different (invisible) tags, the auto-deletion feature, for the files, don’t work as expected.
Background: I’d like to delete the files on a regular base, but won’t like to destroy the folder structure underneath.
My Setup
NC Version 14.0.3 (running on CentOS7 with PostgresDB)
App: file-retention Version 1.3.0
Background jobs: Cron
Files automated tagging
Rule 1 - No-Retention
no_retention_tag (invisible)
File MIME type IS httpd/unix-directory
Rule 2
File MIME type IS NOT httpd/unix-directory
File retention
retention_tag (invisible): 1 days
Check1:
Folders and Files were tagged with the correct tags, when uploaded or manually made.
Files: retentions_tag
Folders: no-retention_tag
Check2:
Folders aren’t deleted after 1 day - correct, works like expected! Files aren’t deleted automatically after 1 day - incorrect, they should be deleted after 1 day (= File Retention Policy)
Can anyone comprehend this behaviour?
Any ideas how I can get fix this?
Addendum:
Today the files were deleted (like expected yesterday) but I had to wait one day longer then expected.
Therefore, I assume that the “file retention time” is not checked in “real time” and probes only in full calendar days (24h, day change).
i also tryied this for all documents but it only works for manualy tagging .
is there any way when a documents gets uploaded autmatically gets a retention policy?
