NCP v 1.12.3
When I start the manual backup process in the NCP panel, I get the message that the backup drive is a read-only file system. With my pi user on the system, I have the correct write / read permissions.
The backups worked always well since setting up the system. The backup drive is 4 TB and new (Western Digital), so there should be enough space left.
Any hints what may be the problem?
[ nc-backup ]
check free space...
du: cannot read directory '/var/www/nextcloud/data/appdata_ock2eglr1ojd/css/icons': Input/output error
clean up old backup /media/Backup_4TB/ncp-backups/nextcloud-bkp_20190429_1556499619.tar
rm: cannot remove '/media/Backup_4TB/ncp-backups/nextcloud-bkp_20190429_1556499619.tar': Read-only file system
Abort...
Maintenance mode already disabled
Abort...
I have writing permission with pi, but somehow the nc user does not. How to fix this?
pi@raspberrypi:~ $ cd /var/www/nextcloud/data/appdata_ock2eglr1ojd/css/
pi@raspberrypi:/var/www/nextcloud/data/appdata_ock2eglr1ojd/css $ ls
activity core files_sharing files_trashbin icons systemtags
comments files files_texteditor firstrunwizard notifications theming
Here the data in the folder on the backup media
139.04GiB 139.04GiB - /media/Backup_4TB/ncp-backups/nextcloud-bkp_20190422_1555894811.tar
187.96GiB 187.96GiB - /media/Backup_4TB/ncp-backups/nextcloud-bkp_20190429_1556499619.tar
191.07GiB 191.07GiB - /media/Backup_4TB/ncp-backups/nextcloud-bkp_20190508_1557277202.tar
191.52GiB 191.52GiB - /media/Backup_4TB/ncp-backups/nextcloud-bkp_20190515_1557882004.tar
709.61GiB 709.61GiB 0.00B /media/Backup_4TB/ncp-backups
