Authentication issue - verifying password endless loop. Nexcloud in docker with reverse proxy
Hi guys
Good morning to all.
I did a fresh install of Nexcloud in Rpi5.
The Nextcloud server (FPM Alpine) is installed on a Raspberry Pi 5 running DietPi, with an NVMe drive and Docker.
The internal web server is Nginx, and the database is MariaDB. The Raspberry Pi 5 (192.168.2.100) is located on the Green network, behind an IPFire firewall (192.168.1.200) connected to a Fritz!Box router (192.168.1.1).
The DMZ network managed by IPFire also contains a Raspberry Pi 4 (172.5.0.5), running DietPi, Docker, and Nginx Proxy Manager (NPM) reverse proxy, configured with the usual Let’s Encrypt certificate.
the issue you are facing:
when I try to install an app or connect the Nextcloud client on an Android smartphone or a Windows PC, the authentication pop-up for password verification appears after I grant authorization, and the process enters an endless loop.
  1. fresh install of Nexcloud in docker and NPM as reverse proxy in a separate server under DMZ (ipfire firewall)
  2. configuration done and working fine in wui
  3. installation of Nextcloud app in smartphone Android or desktop. Once the permission is granted, authentication popup in endless loop
PASTE HERE
PASTE
PASTE HERE
RPI5 - Docker configuration of Nextcloud stack: docker-compose.yaml
services:
  nextcloud-web:
    image: nginx:alpine
    container_name: nextcloud-nginx
    restart: unless-stopped
    ports:
      - "8085:80"
    volumes:
      - /mnt/nvme/docker/nextcloud/app:/var/www/html:ro
      - /mnt/nvme/docker/nextcloud/nginx/nginx.conf:/etc/nginx/conf.d/default.conf:ro
      - /var/log/nginx_internal:/var/log/nginx
    networks:
      - nextcloud-net
    depends_on:
      - nextcloud-app
  nextcloud-app:
    image: nextcloud:fpm-alpine
    container_name: nextcloud-app
    extra_hosts:
      - "host.docker.internal:host-gateway"
    volumes:
      - /var/log/nextcloud:/var/log/nextcloud
      - /mnt/ncUSB/data:/var/www/html/data
    environment:
      - MYSQL_HOST= db
      - MYSQL_DATABASE=nc
      - MYSQL_USER=nc
      - MYSQL_PASSWORD= nc
      - REDIS_HOST=nextcloud-redis
    networks:
      - nextcloud-net
    depends_on:
      - db
      - nextcloud-redis
  db:
    image: mariadb:10.11
    container_name: db
    command: --transaction-isolation=READ-COMMITTED --log-bin=binlog --binlog-format=ROW --log-error=/var/log/mysql/error.log
    volumes:
      - /mnt/nvme/docker/nextcloud/db:/var/lib/mysql
      - /var/log/mariadb:/var/log/mysql
    environment:
      - MYSQL_ROOT_PASSWORD=nc
      - MYSQL_DATABASE=nc
      - MYSQL_USER=nc
    networks:
      - nextcloud-net
  nextcloud-redis:
    image: redis:alpine
    container_name: nextcloud-redis
    volumes:
      - /mnt/nvme/docker/nextcloud/redis:/data
    networks:
      - nextcloud-net
networks:
  nextcloud-net:
    external: true
PI5 internal nginx configuration in docker stack: nginx.conf
server {
    listen 80;
    add_header Strict-Transport-Security "max-age=15552000; includeSubDomains; preload" always;
    server_name cl.xx.it;
    access_log /var/log/nginx/access.log;
    error_log /var/log/nginx/error.log warn;
set_real_ip_from 172.5.0.5;
real_ip_header X-Forwarded-For;
real_ip_recursive on;
    include mime.types;
    types {
        text/javascript mjs;
        application/javascript mjs;
    location ^~ /.well-known {
        location = /.well-known/carddav { return 301 $scheme://$http_host/remote.php/dav/; }
        location = /.well-known/caldav  { return 301 $scheme://$http_host/remote.php/dav/; }
        try_files $uri $uri/ /index.php$request_uri;
    root /var/www/html;
    index index.php index.html;
    client_max_body_size 512M;
    fastcgi_buffers 64 4K;
    location / {
location ~ \.php(?:$|/) {
    include fastcgi_params;
    fastcgi_pass nextcloud-app:9000;
    fastcgi_index index.php;
    fastcgi_param HTTPS on;
    fastcgi_param HTTP_X_FORWARDED_PROTO https;
Sabre\DAV\Exception\NotAuthenticated)
    fastcgi_param HTTP_AUTHORIZATION $http_authorization;
    fastcgi_param SERVER_NAME cl.xx.it;
    fastcgi_param HTTP_HOST cl.xx.it;
    fastcgi_param SERVER_PORT $http_x_forwarded_port;
    fastcgi_param REMOTE_ADDR $remote_addr;
    fastcgi_read_timeout 180s;
    fastcgi_send_timeout 180s;
    location ~ \.(?:css|js|mjs|woff2?|svg|gif|png|jpg|jpeg|ico)$ {
        expires 6M;
        access_log off;
RPI5 nextcloud configuration: config.php
  'instanceid' => 'mio',
  'passwordsalt' => 'mio',
  'secret' => 'mio',
  'version' => '34.0.3.2',
  'dbhost' => 'db',
  'dbname' => 'nc',
  'dbuser' => 'nc',
  'dbpassword' => 'nc',
  'redis' =>
    'host' => 'nextcloud-redis',
    'password' => '',
    'port' => 6379,
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'log_type' => 'file',
  'logfile' => '/var/log/nextcloud/VB_nextcloud.log',
  'loglevel' => 2,
  'logdateformat' => 'F d, Y H:i:s',
    0 => '192.168.2.100:8085',
    1 => 'aa.aa.aa.aa',
    2 => 'cl.xx.it',
    3 => '172.5.0.5',
  'trusted_proxies' =>
    0 => '172.5.0.5',
  'forwarded_for_headers' =>
    0 => 'HTTP_X_FORWARDED_FOR',
  'overwritehost' => 'cl.xx.it',
  'overwrite.cli.url' => 'https://cl.xx.it',
'overwritecondaddr' => '^.*$',
'force_cookies_secure' => true,
  'enable_password_confirmation' => false,
  'session_relaxed_expiry' => true,
  'session_keepalive' => true,
  'remember_login_cookie_lifetime' => 0,
  'session_lifetime' => 86400,
  'remember_login_cookie_lifetime' => 1209600,
  'auth.bruteforce.protection.enabled' => false,
  'bruteforce.whitelist' =>
    0 => '172.5.0.5/24',
  'appstoreenabled' => false,
  'app_install_overwrite' =>
RPI4 in DMZ: NPM reverse proxy configuration
Docker-compose.yaml
services:
  app:
    image: 'jc21/nginx-proxy-manager:latest'
    container_name: nginx-proxy-manager
    ports:
      - '80:80'
      - '81:81'
      - '443:443'
    dns:
      - 1.1.1.1
      - 8.8.8.8
    volumes:
      - /mnt/sd/docker/npm/data:/data
      - /mnt/sd/docker/npm/letsencrypt:/etc/letsencrypt
Proxy host
map $scheme $hsts_header {
    https   "max-age=63072000;includeSubDomains; preload";
server {
  set $forward_scheme http;
  set $server         "192.168.2.100";
  set $port           8085;
  listen 80;
listen [::]:80;
listen 443 ssl;
listen [::]:443 ssl;
  http2 on;
  # Let's Encrypt SSL
  include conf.d/include/letsencrypt-acme-challenge.conf;
  include conf.d/include/ssl-cache.conf;
  include conf.d/include/ssl-ciphers.conf;
  ssl_certificate /etc/letsencrypt/live/npm-19/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/npm-19/privkey.pem;
# Asset Caching
  include conf.d/include/assets.conf;
  # HSTS (ngx_http_headers_module is required) (63072000 seconds = 2 years)
  add_header Strict-Transport-Security $hsts_header always;
    # Force SSL
    set $trust_forwarded_proto "F";
    include conf.d/include/force-ssl.conf;
proxy_set_header Connection $http_connection;
proxy_http_version 1.1;
  access_log /data/logs/proxy-host-3_access.log proxy;
  error_log /data/logs/proxy-host-3_error.log warn;
location / {
    proxy_pass http://192.168.2.100:8085;
    proxy_set_header Host $host;
    proxy_set_header Authorization $http_authorization;
    proxy_pass_header Authorization;
    proxy_set_header X-Forwarded-Proto https;
    proxy_buffering off;
    proxy_request_buffering off;
    proxy_read_timeout 1200s;
    proxy_connect_timeout 1200s;
    proxy_send_timeout 1200s;
    proxy_hide_header Upgrade;
location /.well-known/carddav {
location /.well-known/caldav {
    return 301 $scheme://$host/index.php$uri;
  # Custom
  include /data/nginx/custom/server_proxy[.]conf;
hi @VincenzoNC
if I don’t miss anything you don’t mount config.php into the container - likely your system is no aware of the overwrite* directives. I would recommend to run docker compose exec nextcloud-app php occ config:list system to see the effective system configuration.
For further troubleshooting please review nextcloud.log, reverse proxy log and your browser log (f12) or the respective client log..
