So I uploded some 3000 songs. Now when I click a song it takes 3-4 seconds to start playing. If songs were cached they’ll start playing fast. Also playing from x minute is pausing again. CPU usage is non existant. Drives are SSDs.
It’s the same with videos (playing from x minute).
config regarding caching:
'memcache.local' => '\OC\Memcache\APCu',
'redis' =>
'port' => 0,
'timeout' => 0.0,
),`Predoblikovano besedilo`
What could be the problem? Maybe assign more memory to php?
edit:
nevermind, I forgot I moved stuff to samba share. apparently that’s what causing the slowdown.
