Is it possible to have Audio Player automatically scan the media folder so that new files are imported? I know the scan works when I manually do the scan but is there any other way so that this is done automatically at say 1am in the morning everyday. Thanks so much for any help.
Yes, that is possible.
Just see the official docs at:
Create a cron job doing that for you and you are done.
