Nextcloud 10.0.1 on Ubuntu 16.04
####nextcloud.log
{“reqId”:“K+kPOD1Uwd+WX7RPGICj”,“remoteAddr”:“172.16.16.2”,“app”:“PHP”,“message”:“Uncaught Error: Access to undeclared static property: OC\Files\Filesystem::$normalizedPathCache in /var/www/nextcloud/lib/private/Files/Filesystem.php:773\nStack trace:\n#0 /var/www/nextcloud/lib/private/Files/View.php(2034): OC\Files\Filesystem::normalizePath(‘/ga/files/Edwin…’)\n#1 /var/www/nextcloud/lib/private/Files/View.php(1152): OC\Files\View->unlockFile(‘/Edwin Starr - …’, 1)\n#2 [internal function]: OC\Files\View->OC\Files\{closure}()\n#3 /var/www/nextcloud/apps/files_external/3rdparty/icewind/streams/src/CallbackWrapper.php(109): call_user_func(Object(Closure))\n#4 [internal function]: Icewind\Streams\CallbackWrapper->stream_close()\n#5 {main}\n thrown at /var/www/nextcloud/lib/private/Files/Filesystem.php#773”,“level”:3,“time”:“2016-12-06T03:25:48+00:00”,“method”:“GET”,“url”:“/ocs/v2.php/apps/notifications/api/v1/notifications?format=json”,“user”:“admin”}
{“reqId”:“Qyz5N6iINfMd+Shl8hrw”,“remoteAddr”:“172.16.16.2”,“app”:“PHP”,“message”:“Uncaught Error: Access to undeclared static property: OC\Files\Filesystem::$normalizedPathCache in /var/www/nextcloud/lib/private/Files/Filesystem.php:773\nStack trace:\n#0 /var/www/nextcloud/lib/private/Files/View.php(2034): OC\Files\Filesystem::normalizePath(‘/ga/files/Flora…’)\n#1 /var/www/nextcloud/lib/private/Files/View.php(1152): OC\Files\View->unlockFile(‘/Flora_Purim_-_…’, 1)\n#2 [internal function]: OC\Files\View->OC\Files\{closure}()\n#3 /var/www/nextcloud/apps/files_external/3rdparty/icewind/streams/src/CallbackWrapper.php(109): call_user_func(Object(Closure))\n#4 [internal function]: Icewind\Streams\CallbackWrapper->stream_close()\n#5 {main}\n thrown at /var/www/nextcloud/lib/private/Files/Filesystem.php#773”,“level”:3,“time”:“2016-12-06T03:26:28+00:00”,“method”:“GET”,“url”:“/ocs/v2.php/apps/notifications/api/v1/notifications?format=json”,“user”:“admin-admin”}
{“reqId”:“DjQ5z5I6VKyNQdGZwhlK”,“remoteAddr”:“172.16.16.2”,“app”:“PHP”,“message”:“fwrite() expects parameter 2 to be string, array given at /var/www/nextcloud/lib/private/Files/Storage/Wrapper/Encryption.php#230”,“level”:3,“time”:“2016-12-06T03:28:49+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“admin”}
{“reqId”:“od9KBvbXDrIlkUqbrkgg”,“remoteAddr”:“172.16.16.2”,“app”:“PHP”,“message”:“Uncaught Error: Access to undeclared static property: OC\Files\Filesystem::$normalizedPathCache in /var/www/nextcloud/lib/private/Files/Filesystem.php:773\nStack trace:\n#0 /var/www/nextcloud/lib/private/Files/View.php(2034): OC\Files\Filesystem::normalizePath(‘/ga/files/Edwin…’)\n#1 /var/www/nextcloud/lib/private/Files/View.php(1152): OC\Files\View->unlockFile(‘/Edwin Starr - …’, 1)\n#2 [internal function]: OC\Files\View->OC\Files\{closure}()\n#3 /var/www/nextcloud/apps/files_external/3rdparty/icewind/streams/src/CallbackWrapper.php(109): call_user_func(Object(Closure))\n#4 [internal function]: Icewind\Streams\CallbackWrapper->stream_close()\n#5 {main}\n thrown at /var/www/nextcloud/lib/private/Files/Filesystem.php#773”,“level”:3,“time”:“2016-12-06T03:31:19+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“admin”}
{“reqId”:“RUxoDSev1XcWduJD//Q2”,“remoteAddr”:“172.16.16.2”,“app”:“PHP”,“message”:“Uncaught Error: Access to undeclared static property: OC\Files\Filesystem::$normalizedPathCache in /var/www/nextcloud/lib/private/Files/Filesystem.php:773\nStack trace:\n#0 /var/www/nextcloud/lib/private/Files/View.php(2034): OC\Files\Filesystem::normalizePath(‘/ga/files/Edwin…’)\n#1 /var/www/nextcloud/lib/private/Files/View.php(1152): OC\Files\View->unlockFile(‘/Edwin Starr - …’, 1)\n#2 [internal function]: OC\Files\View->OC\Files\{closure}()\n#3 /var/www/nextcloud/apps/files_external/3rdparty/icewind/streams/src/CallbackWrapper.php(109): call_user_func(Object(Closure))\n#4 [internal function]: Icewind\Streams\CallbackWrapper->stream_close()\n#5 {main}\n thrown at /var/www/nextcloud/lib/private/Files/Filesystem.php#773”,“level”:3,“time”:“2016-12-06T03:32:49+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“admin”}
####Chromium
