Hi!
What would be the minimum system requirements to run an AI Assistant 2.0 fully?
Would it work with a CPU with 4 cores without a dedicated GPU?
If there should be a GPU, what would be the minimum GPU needed?
I would combine it with i7 CPU.
Thank you!
