### ⚠️ This issue respects the following points: ⚠️
- [X] This is a **bug**, no…t a question or a configuration/webserver/proxy issue.
- [X] This issue is **not** already reported on [Github](https://github.com/nextcloud/server/issues?q=is%3Aopen+is%3Aissue+label%3Abug) OR [Nextcloud Community Forum](https://help.nextcloud.com/) _(I've searched it)_.
- [X] Nextcloud Server **is** up to date. See [Maintenance and Release Schedule](https://github.com/nextcloud/server/wiki/Maintenance-and-Release-Schedule) for supported versions.
- [X] I agree to follow Nextcloud's [Code of Conduct](https://nextcloud.com/contribute/code-of-conduct/).
### Bug description
New / fresh installation of Nextcloud 28.0.2
### Steps to reproduce
1. Fresh install of 28.0.2
2. Enable external storage
3. Configure S3 object storage
4. Add user with access to S3 storage
5. Run nocc-cldtst01 files:scan timv (alias to below)
alias nocc-cldtst01="sudo -u www-data php /var/www/cldtst01.site1.com/html/occ"
### Expected behavior
Output
root@X.X.X.X:~$ nocc-cldtst01-site1 files:scan --all
Starting scan for user 1 out of 1 (admin)
Error during scan: Array to string conversion
| Folders | Files | New | Updated | Removed | Errors | Elapsed time |
| 49 | 218 | 0 | 1 | 0 | 84 | 00:00:01 |
root@X.X.X.X:~$
### Installation method
Community Manual installation with Archive
### Nextcloud Server version
28
### Operating system
Debian/Ubuntu
### PHP engine version
PHP 8.2
### Web server
Nginx
### Database engine version
MariaDB
### Is this bug present after an update or on a fresh install?
Fresh Nextcloud Server install
### Are you using the Nextcloud Server Encryption module?
Encryption is Disabled
### What user-backends are you using?
- [X] Default user-backend _(database)_
- [ ] LDAP/ Active Directory
- [ ] SSO - SAML
- [ ] Other
### Configuration report
```shell
root@X.X.X.X:~$ nocc-cldtst01-site1 config:list system
"vmi1517.site1.com",
"cldtst01.site1.com",
"X.X.X.X"
"dbtype": "mysql",
"version": "28.0.2.5",
"overwrite.cli.url": "https:\/\/cldtst01.site1.com",
"dbport": "",
"mysql.utf8mb4": true,
"overwritehost": "cldtst01.site1.com",
"activity_expire_days": 14,
"blacklisted_files": [
".htaccess",
"Thumbs.db",
"thumbs.db"
"cron_log": true,
"default_phone_region": "US",
"enable_previews": true,
"enabledPreviewProviders": [
"OC\\Preview\\PNG",
"OC\\Preview\\JPEG",
"OC\\Preview\\GIF",
"OC\\Preview\\BMP",
"OC\\Preview\\XBitmap",
"OC\\Preview\\Movie",
"OC\\Preview\\PDF",
"OC\\Preview\\MP3",
"OC\\Preview\\TXT",
"OC\\Preview\\MarkDown"
"filesystem_check_changes": 0,
"filelocking.enabled": "true",
"htaccess.RewriteBase": "\/",
"integrity.check.disabled": false,
"knowledgebaseenabled": false,
"log_rotate_size": "104857600",
"logfile": "\/var\/log\/nextcloud\/cldtst01-site1.log",
"loglevel": 2,
"logtimezone": "America\/Los_Angeles",
"overwriteprotocol": "https",
"preview_max_x": 1024,
"preview_max_y": 768,
"preview_max_scale_factor": 1,
"profile.enabled": false,
"redis": {
"port": 0,
"timeout": 0.5,
"dbindex": 1
"quota_include_external_storage": false,
"share_folder": "\/StorageShare",
"skeletondirectory": "",
"trashbin_retention_obligation": "auto, 7"
root@X.X.X.X:~$
### List of activated Apps
```shell
root@X.X.X.X:~$ nocc-cldtst01-site1 app:list
- activity: 2.20.0
- admin_audit: 1.18.0
- cloud_federation_api: 1.11.0
- dav: 1.29.1
- federatedfilesharing: 1.18.0
- files: 2.0.0
- files_external: 1.20.0
- files_pdfviewer: 2.9.0
- files_sharing: 1.20.0
- files_trashbin: 1.18.0
- files_versions: 1.21.0
- logreader: 2.13.0
- lookup_server_connector: 1.16.0
- oauth2: 1.16.3
- password_policy: 1.18.0
- photos: 2.4.0
- privacy: 1.12.0
- provisioning_api: 1.18.0
- serverinfo: 1.18.0
- settings: 1.10.1
- sharebymail: 1.18.0
- text: 3.9.1
- theming: 2.3.0
- twofactor_backupcodes: 1.17.0
- updatenotification: 1.18.0
- viewer: 2.2.0
- workflowengine: 2.10.0
- bruteforcesettings: 2.8.0
- circles: 28.0.0-dev (installed 28.0.0-dev)
- comments: 1.18.0 (installed 1.18.0)
- contactsinteraction: 1.9.0 (installed 1.9.0)
- dashboard: 7.8.0 (installed 7.8.0)
- encryption: 2.16.0
- federation: 1.18.0 (installed 1.18.0)
- files_reminders: 1.1.0 (installed 1.1.0)
- firstrunwizard: 2.17.0 (installed 2.17.0)
- nextcloud_announcements: 1.17.0 (installed 1.17.0)
- notifications: 2.16.0 (installed 2.16.0)
- recommendations: 2.0.0 (installed 2.0.0)
- related_resources: 1.3.0 (installed 1.3.0)
- support: 1.11.0 (installed 1.11.0)
- survey_client: 1.16.0 (installed 1.16.0)
- suspicious_login: 6.0.0
- systemtags: 1.18.0 (installed 1.18.0)
- twofactor_totp: 10.0.0-beta.2
- user_ldap: 1.19.0
- user_status: 1.8.1 (installed 1.8.1)
- weather_status: 1.8.0 (installed 1.8.0)
root@X.X.X.X:~$
### Nextcloud Signing status
```shell
No errors have been found.
### Nextcloud Logs
```shell
root@X.X.X.X:/var/log/nextcloud$ tail -f cldtst01-site1.log
{"reqId":"BsKXnLgxxgk9OrTCg4dN","level":2,"time":"2024-02-06T13:25:37-08:00","remoteAddr":"Z.Z.Z.Z","user":"--","app":"no app in context","method":"POST","url":"/login","message":"Login failed: timv (Remote IP: Z.Z.Z.Z3)","userAgent":"Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36","version":"28.0.2.5","data":[]}
### Additional info
_No response_
