Nitrokey installation instruction lists as prerequisite:
apt update && apt install php-gmp php-bcmath
Are these modules installed in all-in-one?
How can I check?
How could I add if they are not?
How can I check?
I just tested it. Passwordless login via FIDO2/webauthn works out of the box in AIO. I also installed the 2FA webauthn app and no issues there either. So Iād say yes, the relevant PHP modules are installed ![]()
It took some time - not sure, neither know why -, but know a usb-key is selectable for totp.
