Nextcloud: 20.0.12
Operating system and version: Ubuntu 16.04.1
Apache: 2.4.18
PHP: 7.3
Appstore won’t show categories on the left. Checking logs it says curl error 60, ssl.
I’ve upgraded ca-certificates, I’ve even downloaded the new crt file for nextcloud and replaced the old in the config dir.
When I run curl to the Appstore url from the command line it works, no errors. If I open php interactive and run file_get_contents to the Appstore url it works also.
But can’t get the Appstore to work.
Do you like to use the app store in cli or browser?
Browser, didn’t know I could run Appstore from OCC in the cli?
For browser usage there should be no need to manually update any cert.
Or did I miss any information? You talked about config dir.
Which browser are you using?
Don’t see why browser would matter, since I can go to the Appstore url from that browser no issue. Firefox latest edition. Tried chrome as well.
Logs are massive, let me see if I can copy paste the error, I’m on mobile.
Finally found the issue after digging through the log once more!
For all those looking, file /var/data/files_external/rootcerts.crt
needed replaced with the one from git repo ca-bundle.crt
This line from the logs I found was complaining about that file:
"message": {
"Exception": "GuzzleHttp\\Exception\\RequestException",
"Message": "cURL error 60: SSL certificate problem: certificate has expired (see https://curl.haxx.se/libcurl/c/libcurl-errors.html)",
"Code": 0,
"Trace": [{
"file": "/var/www/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php",
"line": 155,
"function": "createRejection",
"class": "GuzzleHttp\\Handler\\CurlFactory",
"type": "::",
"args": [{
"sink": {
"__class__": "GuzzleHttp\\Psr7\\Stream"
"headers": [],
"response": null,
"request": {
"__class__": "GuzzleHttp\\Psr7\\Request"
"options": {
"verify": "/var/data/files_external/rootcerts.crt",
"timeout": 60,
"synchronous": true,
"handler": {
"__class__": "GuzzleHttp\\HandlerStack"
All good now, now it loads the appstore. Thanks!
