apps.nextcloud.com is not reachable from my public IP (possible IP block)
Issue: apps.nextcloud.com not reachable from my public IP
Hello!
Our network cannot access https://apps.nextcloud.com from our public IP:
160.20.200.210
What happens
  • ERR_CONNECTION_TIMED_OUT for any device on our network
  • curl and ping do not respond
  • traceroute stops in the upstream provider
  • No firewall rules on our side blocking this
  • The site works normally from:
    • 4G mobile network
    • Another ISP
    • VPN connection
This strongly suggests that our IP is blocked or rate-limited by the App Store infrastructure (Hetzner).
Expected behaviour
The domain https://apps.nextcloud.com should load normally.
Additional information
Please check if the IP 160.20.200.210 is blocked on your side and whitelist it if possible.Thank you
There are several fail2ban-filters:
If there are more than 15 accesses to the “main” apps.json or more than 10 accesses to platform-specific apps.json files within 10 minutes, the IP address is jailed for one hour.
If this:
curl -s -o /dev/null -w '%{http_code}\n' -I https://apps.nextcloud.com/
.. answers you with return code 429, then your IP is rate-limited for one hour.
h.t.h.
ernolf
Please don’t open the same issue on different plattforms or at least link them: apps.nextcloud.com is not reachable from my public IP (possible IP block) · Issue #1674 · nextcloud/appstore · GitHub
