Apps management not loading
BTW, the GitHub request is probably not the only one that fails because we don’t host the JSON on GitHub afaik. GitHub sometimes hosts the app’s images and archives, that’s all
So basically: dig deeper into those logs :wink:
After a reinstall i got an error saying nextcloud can’t reach the internet(That didn’t even show up before).
Internet connection of the system was perfect, so it turns out nextcloud isn’t using system proxy.
Added the proxy to config.php and everything works fine.
Thanks for your help anyway.
