I reported this on github but did not get any response, on a new and fresh NC installation, I have been getting this error randomly since start. I do not use or have spreed enabled (unless it comes by default)
Steps to reproduce
- Not exactly sure why or how it appears, I just see/find this error in my nextcloud.log No errors in nginx.log or PHP log or visible issues with installation.
Expected behaviour
Error doesn’t appear
Actual behaviour
Error | index | OCP\App\AppPathNotFoundException: Could not find path for spreed
Server configuration
Ubuntu 18.04
Nginx
Mysql/MariaDB
PHP-FPM 7.02
Nextcloud 15.0.4
Updated from an older Nextcloud/ownCloud or fresh install:
Fresh Install
Where did you install Nextcloud from:
Nextcloud Website (zip package)
Signing status:
Signing status
List of activated apps:
App list
Nextcloud configuration:
Config report
Are you using external storage, if yes which one: None
Are you using encryption: No
Are you using an external user-backend, if yes which one: None
Client configuration
Browser:
Chrome
Operating system:
Windows 10
Nextcloud log (data/nextcloud.log)
/home/dataonair.com/core/Controller/SvgController.php - line 99:
OC\App\AppManager->getAppPath("spreed")
/home/dataonair.com/lib/private/AppFramework/Http/Dispatcher.php - line 166:
OC\Core\Controller\SvgController->getSvgFromApp("spreed", "app-dark", "000")
/home/dataonair.com/lib/private/AppFramework/Http/Dispatcher.php - line 99:
OC\AppFramework\Http\Dispatcher->executeController(OC\Core\Cont ... {}, "getSvgFromApp")
/home/dataonair.com/lib/private/AppFramework/App.php - line 118:
OC\AppFramework\Http\Dispatcher->dispatch(OC\Core\Cont ... {}, "getSvgFromApp")
/home/dataonair.com/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47:
OC\AppFramework\App::main("OC\\Core\\C ... r", "getSvgFromApp", OC\AppFramew ... {}, { app: "spre ... "})
<<closure>>
OC\AppFramework\Routing\RouteActionHandler->__invoke({ app: "spre ... "})
/home/dataonair.com/lib/private/Route/Router.php - line 297:
call_user_func(OC\AppFramew ... {}, { app: "spre ... "})
/home/dataonair.com/lib/base.php - line 987:
OC\Route\Router->match("/svg/spreed/app-dark")
/home/dataonair.com/index.php - line 42:
OC::handleRequest()
