AppOrder and TOTP – wrong landing page
Hi Community!
I use NC 9.1.0.16 and AppOrder 0.3.2 together with Two Factor TOTP 0.4.1.
Does anyone has the problem that, with activated TOTP, the landing page is ignored?
The setting 'defaultapp' => 'apporder', is in the config.php and the first app in the list of AppOrder is not files. Nevertheless, the Files app is launched after login. Without TOTP the correct landing page (app) is used.
Thanks in advance for every hint.
This seems to be a bug in the two factor code of Nextcloud. It is already fixed on master but currently not backported.
See: https://github.com/nextcloud/server/pull/1188
@juliusknorr Thanks for pointing me in the right direction. And thank you too for this very helpful app!
@ChristophWurst Thanks for your PR.
