Apache Container Stuck at (Starting) - Cannot Connect to Nextcloud Instance
I have been using Nexcloud AIO for a long while without issues. I suddenly was unable to reach my NC instance yesterday.
I am using Nextcloud AIO V11.6.0
I am using OMV 7.715-2 (sandworm) as the operating system. I am using DuckDns and a reverse proxy with NPM.
My NC AIO interface indicates that all containers have started other than Apache, which indicates that it is “starting.”
I have tried recreating the Nextcloud AIO network per GitHub #4989, but that did not work. I have scoured the forums for solutions, but nothing has worked.
I have posted the log entry for Apache from my Nextcloud AIO. The following errors are repeated in the log:
2025-09-04T16:25:59.537314562Z /usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See Package Discovery and Resource Access using pkg_resources - setuptools 80.9.0 documentation. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
2025-09-04T16:25:59.537355173Z import pkg_resources
2025-09-04T16:26:03.909712998Z SIGILL: illegal instruction
2025-09-04T16:26:04.468998738Z [Thu Sep 04 12:26:04.468426 2025] [mpm_event:notice] [pid 108:tid 108] AH00489: Apache/2.4.65 (Unix) configured – resuming normal operations
2025-09-04T16:26:04.469039497Z [Thu Sep 04 12:26:04.468520 2025] [core:notice] [pid 108:tid 108] AH00094: Command line: ‘/usr/local/apache2/bin/httpd -D FOREGROUND’
2025-09-04T16:26:05.483887124Z SIGILL: illegal instruction
I pressed “create topic” prematurely for an earlier attempt to make this post. Please delete that post. Thank you in advance for your assistance.
[/details]
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
025-09-04T16:09:42.297511690Z Waiting for Nextcloud to start...
2025-09-04T16:09:47.305403656Z Waiting for Nextcloud to start...
2025-09-04T16:09:52.308245899Z Waiting for Nextcloud to start...
2025-09-04T16:09:57.310567078Z Waiting for Nextcloud to start...
2025-09-04T16:10:02.312761225Z Waiting for Nextcloud to start...
2025-09-04T16:10:07.314888436Z Waiting for Nextcloud to start...
2025-09-04T16:10:12.317156939Z Waiting for Nextcloud to start...
2025-09-04T16:10:17.320288862Z Connection to nextcloud-aio-nextcloud (172.22.0.9) 9000 port [tcp/*] succeeded!
2025-09-04T16:10:17.432964285Z SIGILL: illegal instruction
2025-09-04T16:10:18.349657015Z /usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
2025-09-04T16:10:18.349709597Z   import pkg_resources
2025-09-04T16:10:19.524942918Z SIGILL: illegal instruction
2025-09-04T16:10:19.611400246Z [Thu Sep 04 12:10:19.610872 2025] [mpm_event:notice] [pid 54:tid 54] AH00489: Apache/2.4.65 (Unix) configured -- resuming normal operations
2025-09-04T16:10:19.611441934Z [Thu Sep 04 12:10:19.610945 2025] [core:notice] [pid 54:tid 54] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
2025-09-04T16:10:20.625754408Z SIGILL: illegal instruction
2025-09-04T16:10:22.642372455Z SIGILL: illegal instruction
2025-09-04T16:10:25.658635493Z SIGILL: illegal instruction
2025-09-04T16:17:32.893211995Z Connection to nextcloud-aio-nextcloud (172.22.0.9) 9000 port [tcp/*] succeeded!
2025-09-04T16:17:32.919310120Z SIGILL: illegal instruction
2025-09-04T16:17:33.110650929Z /usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
2025-09-04T16:17:33.110684551Z   import pkg_resources
2025-09-04T16:17:34.162055763Z SIGILL: illegal instruction
2025-09-04T16:17:34.181561202Z [Thu Sep 04 12:17:34.181030 2025] [mpm_event:notice] [pid 29:tid 29] AH00489: Apache/2.4.65 (Unix) configured -- resuming normal operations
2025-09-04T16:17:34.181615063Z [Thu Sep 04 12:17:34.181112 2025] [core:notice] [pid 29:tid 29] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
2025-09-04T16:17:35.195276618Z SIGILL: illegal instruction
2025-09-04T16:17:37.522763047Z SIGILL: illegal instruction
2025-09-04T16:17:40.539581271Z SIGILL: illegal instruction
2025-09-04T16:23:47.874000968Z Waiting for Nextcloud to start...
2025-09-04T16:23:53.055020967Z Waiting for Nextcloud to start...
2025-09-04T16:23:58.057838215Z Waiting for Nextcloud to start...
2025-09-04T16:24:03.060524520Z Waiting for Nextcloud to start...
2025-09-04T16:24:08.062706834Z Waiting for Nextcloud to start...
2025-09-04T16:24:13.066063760Z Waiting for Nextcloud to start...
2025-09-04T16:24:18.069370475Z Waiting for Nextcloud to start...
2025-09-04T16:24:23.072961052Z Waiting for Nextcloud to start...
2025-09-04T16:24:28.076202738Z Waiting for Nextcloud to start...
2025-09-04T16:24:33.078732784Z Waiting for Nextcloud to start...
2025-09-04T16:24:38.080806640Z Waiting for Nextcloud to start...
2025-09-04T16:24:43.084071833Z Waiting for Nextcloud to start...
2025-09-04T16:24:48.086790949Z Waiting for Nextcloud to start...
2025-09-04T16:24:53.089845294Z Waiting for Nextcloud to start...
2025-09-04T16:24:58.092817205Z Waiting for Nextcloud to start...
2025-09-04T16:25:03.096204969Z Waiting for Nextcloud to start...
2025-09-04T16:25:08.099434971Z Waiting for Nextcloud to start...
2025-09-04T16:25:13.101917390Z Waiting for Nextcloud to start...
2025-09-04T16:25:18.103886886Z Waiting for Nextcloud to start...
2025-09-04T16:25:23.106922087Z Waiting for Nextcloud to start...
2025-09-04T16:25:28.110337040Z Waiting for Nextcloud to start...
2025-09-04T16:25:33.114205902Z Waiting for Nextcloud to start...
2025-09-04T16:25:38.117888679Z Waiting for Nextcloud to start...
2025-09-04T16:25:43.255136220Z Connection to nextcloud-aio-nextcloud (172.22.0.9) 9000 port [tcp/*] succeeded!
2025-09-04T16:25:54.767607292Z SIGILL: illegal instruction
2025-09-04T16:25:59.537314562Z /usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
2025-09-04T16:26:04.468998738Z [Thu Sep 04 12:26:04.468426 2025] [mpm_event:notice] [pid 108:tid 108] AH00489: Apache/2.4.65 (Unix) configured -- resuming normal operations
2025-09-04T16:26:04.469039497Z [Thu Sep 04 12:26:04.468520 2025] [core:notice] [pid 108:tid 108] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
2025-09-04T16:26:07.500479826Z SIGILL: illegal instruction
2025-09-04T16:26:10.516850526Z SIGILL: illegal instruction
PASTE
PASTE HERE
PASTE HERE
