Nextcloud version: 26.0.0.x (helm chart 3.5.5)
Operating system and version: docker nextcloud container
Hi all, did anyone manage to deploy Nextcloud on K8S, using EFS as the primary storage? The docs say that a ReadWriteMany filesystem is required, but simply using that results in this bug, and after a couple of hours I just gave up.
Maybe I missed the one way this would have worked, and others have found it – so … anyone?
All my helm value files contained something around this:
persistence:
enabled: true
storageClass: efs-sc
accessMode: ReadWriteMany
nextcloudData:
# will ONLY work if persistence.enabled == true as well.
- use helm with the above config snippet (or adjust this pastebin to your needs)
- do
helm install - watch the error from this link appear
The output of your Nextcloud log in Admin > Logging: nextcloud is not coming up.
The output of your config.php file in /path/to/nextcloud: unchanged to standard install with ReadWriteOnce persistance enabled.
The output of your Apache/nginx/system log in /var/log/____: irrelevant.
Output errors in nextcloud.log: irrelevant, the error is caused by entrypoint.sh it seems.
