Any upcoming features for Nextcloud Forms and Polls
I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
Hello everyone,
I use Nextcloud Forms and Polls within my team, especially for gathering opinions on projects. In recent months, the demand for these tools has increased, and several departments have also expressed interest in using them - however, with more advanced requirements.
Some of the requested features include:
  • matrix questions: dynamic follow-up questions based on previous answers (e.g., a new question appears if “No” is selected in previous)
  • grouping of questions for better structure complex surveys
  • use of templates
    Are there any plans for an upcoming update to Nextcloud Forms or Polls that would integrate these or similar features? I would appreciate any insights from the community or updates on the roadmap.
    Best regards,
    florianh
Best way is to check the bug trackers, where they also gather enhancement ideas:
Hi @florianh
your requests are already tracked for Forms. However, I can’t tell you when they will be implemented. But you’re more than welcome to start working on it :slight_smile:
You can already achieve this by creating your Form as a template, close/archive it and then use the “Copy form” action to create new forms from that template :slight_smile: Other than that, theres also a feature request:
Best regards
Chris
Hello @Chartman123 ,
thank you for your response! It’s great to hear that these requests are already being tracked for Forms. I also find it quite interesting how high the demand for this feature seems to be.
As a Forms enthusiast I’m happy that these features are more likely to be added in Forms :grin:.
At the moment, I don’t have the capacity to work on this myself, but I’ll definitely keep an eye on updates and future developments.
Best regards,
florianh
