Nextcloud version: 20.0.0.9
Operating system and version: Debian 10
Apache or nginx version: nginx/1.18.0
PHP version: 7.4
You won’t see any files on the Nextcloud Android app. It doesn’t matter if you have a new connected account or an already connected account.
- Log on to the Nextcoud instance.
- Open the Nextcloud App
{"reqId":"Lty38F6YaIRKczNpsl82","level":4,"time":"06.10.2020 13:13:19","remoteAddr":"80.187.106.146","user":"1e9fb3c8-a990-1036-844e-33b12343625b","app":"webdav","method":"PROPFIND","url":"/remote.php/webdav/","message":{"Exception":"TypeError","Message":"Argument 1 passed to OC\\Group\\Manager::getUserGroupIds() must implement interface OCP\\IUser, null given, called in /var/www/DOMAIN/lib/private/Share20/DefaultShareProvider.php on line 884","Code":0,"Trace":[{"file":"/var/www/DOMAIN/lib/private/Share20/DefaultShareProvider.php","line":884,"function":"getUserGroupIds","class":"OC\\Group\\Manager","type":"->"},{"file":"/var/www/DOMAIN/lib/private/Share20/Manager.php","line":1333,"function":"getSharedWith","class":"OC\\Share20\\DefaultShareProvider","type":"->"},{"file":"/var/www/DOMAIN/apps/dav/lib/Connector/Sabre/Node.php","line":323,"function":"getSharedWith","class":"OC\\Share20\\Manager","type":"->"},{"file":"/var/www/DOMAIN/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":372,"function":"getNoteFromShare","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":96,"function":"OCA\\DAV\\Connector\\Sabre\\{closure}","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/DOMAIN/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":374,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/Server.php","line":1063,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/Server.php","line":989,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/Server.php","line":1678,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/Server.php","line":1661,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":363,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/Server.php","line":474,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/apps/dav/appinfo/v1/webdav.php","line":84,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/DOMAIN/remote.php","line":167,"args":["/var/www/DOMAIN/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/var/www/DOMAIN/lib/private/Group/Manager.php","Line":325,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"20.0.0.9"}
'passwordsalt' => 'SALT',
0 => 'DOMAIN',
'datadirectory' => '/home/_data',
'skeletondirectory' => '/home/_skeleton',
'tempdirectory' => '/home/box_temp',
'version' => '20.0.0.9',
'dbname' => 'db',
'dbhost' => 'localhost',
'dbuser' => 'db',
'dbpassword' => 'PW',
'loglevel' => 3,
'logdateformat' => 'd.m.Y H:i:s',
'log_rotate_size' => 10 * 1024 * 1024,
'secret' => 'SECRET',
'ldapIgnoreNamingRules' => false,
'forcessl' => true,
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'ADRESS',
'mail_domain' => 'OTHERDOMAIN',
'mail_smtphost' => 'mail.OTHERDOMAIN',
'mail_smtpport' => '25',
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'ldapUserCleanupInterval' => 51,
'lost_password_link' => 'https://www.OTHERDOMAIN/de/user/password',
'instanceid' => 'oc4zv99hzps1',
'mail_smtpauth' => 1,
'mail_smtpname' => '',
'mail_smtppassword' => '',
'overwrite.cli.url' => 'https://DOMAIN',
'redis' =>
'port' => 0,
'timeout' => 0.0,
'default_language' => 'de',
'default_locale' => 'de',
'trashbin_retention_obligation' => 'auto, 60',
'versions_retention_obligation' => 'auto, 60',
'theme' => 'THEME',
'simpleSignUpLink' => 'false',
'activity_expire_days' => '90',
nothing that has to do with this error
