An SQL query locks up a thread for several minutes, every few minutes
example
longer
example
here
Nextcloud version (eg, 29.0.5): Nextcloud Hub 8 (30.0.6)
Operating system and version (eg, Ubuntu 24.04): Debian Bookworm
Apache or nginx version (eg, Apache 2.4.25): 2.4.62
PHP version (eg, 8.3): 8.2
Nextcloud executes an SQL query every few minutes that locks up a thread on my mariadb server for minutes at a time.
This is an old Nextcloud install that I’ve kept up to date for several years. it’s just something I run for free for friends and family but it has grown quite large. We have ~3.5TB of files.
As you can see from the screenshots included, I have 4 virtual cores devoted to my database VM. While this query is executing, one of the cores is pegged at 100%
See screenshot for the query being executed. I should mention, the table “oc_filecache” has ~6.3 million rows million rows. or about 2.3GiB
I really only understand the very basics of SQL so I’m not sure what I can do to improve the performance of this query.
Is this the first time you’ve seen this error? (Y/N): It’s something that’s gotten worse over time as the oc_filecache table has grown. I’ve posted about this problem before. but I don’t feel I got any great answers. I still don’t know what this query does
  1. Have a nextcloud server with millions of files, i guess. not sure.
There doesn't seem to be any relevant log output at the warn level.
  'instanceid' => 'REDACTED',
  'passwordsalt' => 'REDACTED',
  'secret' => 'REDACTED',
    0 => 'REDACTED',
    1 => 'REDACTED',
    2 => 'REDACTED',
  'datadirectory' => '/home/ocdata/',
  'overwrite.cli.url' => 'REDACTED',
  'version' => '29.0.9.2',
  'dbname' => 'nextcloud',
  'dbhost' => 'REDACTED-databaseVM',
  'dbuser' => 'REDACTED',
  'dbpassword' => 'REDACTED',
  'logtimezone' => 'UTC',
  'default_phone_region' => 'US',
  'mail_smtpmode' => 'sendmail',
  'mail_from_address' => 'admin',
  'mail_domain' => 'REDACTED',
  'loglevel' => 0,
  'redis' =>
    'port' => 0,
    'dbindex' => 0,
    'timeout' => 1.5,
  'appstore.experimental.enabled' => true,
  'theme' => '',
  'has_rebuilt_cache' => true,
  'twofactor_enforced' => 'true',
    0 => 'admin',
    1 => 'registered',
    2 => 'Users',
  'enforce_theme' => '',
  'maintenance_window_start' => 3,
redacted log provided if needed. I dont see any relevant entries
Maybe there’s an index I could add?
