example
longer
example
here
Nextcloud version (eg, 12.0.2): 15.0.4
Operating system and version (eg, Ubuntu 17.04): Debian 9
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.25 (Debian)
PHP version (eg, 7.1): PHP 7.2.14-1
- An exception occurred while file uploading to S3
Sabre\DAV\Exception: An exception occurred while uploading parts to a multipart upload. The following parts had errors: - Part 1: Error executing "UploadPart" on "http://se.sima-land.local/major/2.jpeg?partNumber=1&uploadId=2~dwxXsjzMdoNy0HcuE3A0ksxG7PZcuXm"; AWS HTTP error: Server error: `PUT http://se.sima-land.local/major/2.jpeg?partNumber=1&uploadId=2~dwxXsjzMdoNy0HcuE3A0ksxG7PZcuXm` resulted in a `500 Internal Server Error` response: <?xml version="1.0" encoding="UTF-8"?><Error><Code>UnknownError</Code><BucketName>major</BucketName><RequestId>tx0000000 (truncated...) UnknownError (server): - <?xml version="1.0" encoding="UTF-8"?><Error><Code>UnknownError</Code><BucketName>major</BucketName><RequestId>tx000000000000000ece8f1-005c5d89e4-68f6ba7-se-k8</RequestId><HostId>68f6ba7-se-k8-se</HostId></Error>
/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php - line 209:
OCA\DAV\Connector\Sabre\File->convertToSabreException(Aws\S3\Excep ... {})
/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php - line 156:
OCA\DAV\Connector\Sabre\File->put(null)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 1096:
OCA\DAV\Connector\Sabre\Directory->createFile("2.jpeg", null)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 525:
Sabre\DAV\Server->createFile("Ceph_S3/2.jpeg", null, null)
<<closure>>
Sabre\DAV\CorePlugin->httpPut(Sabre\HTTP\R ... "}, Sabre\HTTP\Response {})
/var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105:
call_user_func_array([ Sabre\DAV\ ... "], [ Sabre\HTTP ... }])
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479:
Sabre\Event\EventEmitter->emit("method:PUT", [ Sabre\HTTP ... }])
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254:
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\R ... "}, Sabre\HTTP\Response {})
/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php - line 80:
Sabre\DAV\Server->exec()
/var/www/nextcloud/remote.php - line 163:
require_once("/var/www/ne ... p")
ЗапротоколированоAws\S3\Exception\S3MultipartUploadException: An exception occurred while uploading parts to a multipart upload. The following parts had errors: - Part 1: Error executing "UploadPart" on "http://se.sima-land.local/major/2.jpeg?partNumber=1&uploadId=2~dwxXsjzMdoNy0HcuE3A0ksxG7PZcuXm"; AWS HTTP error: Server error: `PUT http://se.sima-land.local/major/2.jpeg?partNumber=1&uploadId=2~dwxXsjzMdoNy0HcuE3A0ksxG7PZcuXm` resulted in a `500 Internal Server Error` response: <?xml version="1.0" encoding="UTF-8"?><Error><Code>UnknownError</Code><BucketName>major</BucketName><RequestId>tx0000000 (truncated...) UnknownError (server): - <?xml version="1.0" encoding="UTF-8"?><Error><Code>UnknownError</Code><BucketName>major</BucketName><RequestId>tx000000000000000ece8f1-005c5d89e4-68f6ba7-se-k8</RequestId><HostId>68f6ba7-se-k8-se</HostId></Error>
<<closure>>
Aws\Multipart\AbstractUploadManager->Aws\Multipart\{closure}("*** sensiti ... *")
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Coroutine.php - line 122:
Generator->send(null)
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 203:
GuzzleHttp\Promise\Coroutine->_handleSuccess(null)
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 156:
GuzzleHttp\Promise\Promise::callHandler(1, null, [ GuzzleHttp ... ]])
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php - line 47:
GuzzleHttp\Promise\Promise::GuzzleHttp\Promise\{closure}("*** sensiti ... *")
/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlMultiHandler.php - line 98:
GuzzleHttp\Promise\TaskQueue->run()
/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlMultiHandler.php - line 125:
GuzzleHttp\Handler\CurlMultiHandler->tick()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 246:
GuzzleHttp\Handler\CurlMultiHandler->execute("*** sensiti ... *")
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 223:
GuzzleHttp\Promise\Promise->invokeWaitFn()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 267:
GuzzleHttp\Promise\Promise->waitIfPending()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 225:
GuzzleHttp\Promise\Promise->invokeWaitList()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 62:
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Coroutine.php - line 65:
GuzzleHttp\Promise\Promise->wait()
GuzzleHttp\Promise\Coroutine->GuzzleHttp\Promise\{closure}("*** sensiti ... *")
/var/www/nextcloud/3rdparty/aws/aws-sdk-php/src/Multipart/AbstractUploadManager.php - line 83:
/var/www/nextcloud/lib/private/Files/ObjectStore/S3ObjectTrait.php - line 81:
Aws\Multipart\AbstractUploadManager->upload()
/var/www/nextcloud/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 639:
OCA\Files_External\Lib\Storage\AmazonS3->writeObject("2.jpeg", null)
/var/www/nextcloud/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 469:
OCA\Files_External\Lib\Storage\AmazonS3->writeBack("/tmp/oc_tmp_5kCqPz", "2.jpeg")
<<closure>>
OCA\Files_External\Lib\Storage\AmazonS3->OCA\Files_External\Lib\Storage\{closure}("*** sensiti ... *")
/var/www/nextcloud/apps/files_external/3rdparty/icewind/streams/src/CallbackWrapper.php - line 109:
call_user_func(Closure {})
<<closure>>
Icewind\Streams\CallbackWrapper->stream_close()
/var/www/nextcloud/lib/private/Files/Storage/Common.php - line 829:
fclose(null)
/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php - line 630:
OC\Files\Storage\Common->writeStream("2.jpeg", null, null)
OC\Files\Storage\Wrapper\Wrapper->writeStream("2.jpeg", null, null)
/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php - line 169:
OC\Files\Storage\Wrapper\Wrapper->writeStream("2.jpeg", null)
<<closure>>
127.0.0.1:80 10.170.1.45 - - [08/Feb/2019:18:52:45 +0500] "PUT /nextcloud/remote.php/webdav/Ceph_S3/2.jpeg HTTP/1.1" 500 1661 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:65.0) Gecko/20100101 Firefox/65.0"
127.0.0.1:80 10.170.1.45 - - [08/Feb/2019:18:52:45 +0500] "GET /nextcloud/index.php/apps/files/ajax/getstoragestats.php?dir=%2FCeph_S3 HTTP/1.1" 200 1168 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:65.0) Gecko/20100101 Firefox/65.0"
127.0.0.1:80 10.170.1.45 - - [08/Feb/2019:18:52:46 +0500] "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 1564 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:65.0) Gecko/20100101 Firefox/65.0"
127.0.0.1:80 10.170.1.45 - - [08/Feb/2019:18:52:39 +0500] "GET /nextcloud/index.php/apps/logreader/poll?lastReqId=luXDAYYIPkKKE8vv7yzs HTTP/1.1" 200 24552 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:65.0) Gecko/20100101 Firefox/65.0"
