Hi at all,
I am having problems flashing or installing NextCloudPi in general to a 32 GB micro sd card.
After flashing the NextCloudPi_RPi_03-28-20.img file with balena Etcher from here I try to access the NCP-webinterface over the assigned IP or dns-name, but I am getting the
"403 Forbidden - You don't have permission to access this resource."
error and I can’t reach the activation page.
What I did so far without success:
- Searching in the Nextcloud community and in Google, but couldn’t find a solution
- Add an exception in Mozilla Firefox for the non valid certificate
- Try other browser like Edge or Internet Explorer → same error…
- Flashing a clean Raspbian Buster image and install NextCloudPi with
wget https://raw.githubusercontent.com/nextcloud/nextcloudpi/master/install.sh
sudo bash install.sh → same error… - Activate nc-webui by ncp-config → same error…
My environment:
- I access the Raspberry Pi via Wifi
- SSH access is possible
My nextcloud.conf:
/etc/apache2/sites-available $ cat nextcloud.conf
DocumentRoot /var/www/nextcloud
CustomLog /var/log/apache2/nc-access.log combined
ErrorLog /var/log/apache2/nc-error.log
SSLEngine on
SSLCertificateFile /etc/ssl/certs/ssl-cert-snakeoil.pem
SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key
Options +FollowSymlinks
AllowOverride All
Dav off
LimitRequestBody 0
SSLRenegBufferSize 10486000
NextCloudPi diagnostics:
NextCloudPi version v1.24.0
NextCloudPi image NextCloudPi_03-28-20
distribution Raspbian GNU/Linux 10 \n \l
automount no
USB devices none
datadir /var/www/nextcloud/data
data in SD yes
data filesystem ext2/ext3
data disk usage 2.1G/29G
rootfs usage 2.1G/29G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 18.0.3.0
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 closed
port check 443 closed
IP ***REMOVED SENSITIVE VALUE***
gateway ***REMOVED SENSITIVE VALUE***
interface wlan0
certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
uptime 9min
Nextcloud configuration
"trusted_domains": {
"0": "localhost",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"11": "2003:f4:ef36:f400:a2ef:51c:***REMOVED***",
"1": "11.***REMOVED***"
"dbtype": "mysql",
"version": "18.0.3.0",
"overwrite.cli.url": "http:\/\/localhost",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"tempdirectory": "\/var\/www\/nextcloud\/data\/tmp",
"mail_smtpmode": "sendmail",
"mail_smtpauthtype": "LOGIN",
"preview_max_x": "2048",
"preview_max_y": "2048",
"jpeg_quality": "60",
"overwriteprotocol": "https"
HTTPd logs
[Thu Feb 13 16:10:23.283988 2020] [ssl:warn] [pid 736:tid 3069231632] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Thu Feb 13 16:10:23.284769 2020] [ssl:error] [pid 736:tid 3069231632] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: CN=archlinux / issuer: CN=archlinux / serial: 2A964521A5A0AD28440B39B1D781ABFDD1281F7C / notbefore: Mar 28 20:04:49 2020 GMT / notafter: Mar 26 20:04:49 2030 GMT]
[Thu Feb 13 16:10:23.284810 2020] [ssl:error] [pid 736:tid 3069231632] AH02604: Unable to configure certificate localhost:443:0 for stapling
[Thu Feb 13 16:10:23.406798 2020] [ssl:warn] [pid 1063:tid 3069231632] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Thu Feb 13 16:10:24.329770 2020] [ssl:error] [pid 1063:tid 3069231632] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: CN=archlinux / issuer: CN=archlinux / serial: 2A964521A5A0AD28440B39B1D781ABFDD1281F7C / notbefore: Mar 28 20:04:49 2020 GMT / notafter: Mar 26 20:04:49 2030 GMT]
[Thu Feb 13 16:10:24.329848 2020] [ssl:error] [pid 1063:tid 3069231632] AH02604: Unable to configure certificate localhost:443:0 for stapling
[Thu Feb 13 16:10:24.340397 2020] [mpm_event:notice] [pid 1063:tid 3069231632] AH00489: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1d configured -- resuming normal operations
[Thu Feb 13 16:10:24.340519 2020] [core:notice] [pid 1063:tid 3069231632] AH00094: Command line: '/usr/sbin/apache2'
[Tue Mar 31 14:31:44.599190 2020] [authz_host:error] [pid 1065:tid 2755138592] [client 11.***:60086] AH01753: access check of 'localhost' to / failed, reason: unable to get the remote host name
[Tue Mar 31 14:31:44.599353 2020] [authz_core:error] [pid 1065:tid 2755138592] [client 11.***:60086] AH01630: client denied by server configuration: /var/www/ncp-web/
[Tue Mar 31 14:31:44.628684 2020] [authz_host:error] [pid 1065:tid 2755138592] [client 11.***:60086] AH01753: access check of 'localhost' to /favicon.ico failed, reason: unable to get the remote host name
[Tue Mar 31 14:31:44.628753 2020] [authz_core:error] [pid 1065:tid 2755138592] [client 11.***:60086] AH01630: client denied by server configuration: /var/www/ncp-web/favicon.ico
Database logs
2020-02-13 16:10:31 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-02-13 16:10:31 0 [Note] InnoDB: Number of pools: 1
2020-02-13 16:10:31 0 [Note] InnoDB: Using generic crc32 instructions
2020-02-13 16:10:31 0 [Note] InnoDB: Initializing buffer pool, total size = 1.625G, instances = 1, chunk size = 128M
2020-02-13 16:10:31 0 [Note] InnoDB: Completed initialization of buffer pool
2020-02-13 16:10:31 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-02-13 16:10:31 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2020-02-13 16:10:31 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-02-13 16:10:31 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-02-13 16:10:31 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-02-13 16:10:31 0 [Note] InnoDB: Waiting for purge to start
2020-02-13 16:10:31 0 [Note] InnoDB: 10.3.22 started; log sequence number 4286416; transaction id 2809
2020-02-13 16:10:31 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2020-02-13 16:10:31 0 [Note] Plugin 'FEEDBACK' is disabled.
2020-02-13 16:10:31 0 [Note] Server socket created on IP: '127.0.0.1'.
2020-02-13 16:10:31 0 [Note] Reading of all Master_info entries succeeded
2020-02-13 16:10:31 0 [Note] Added new Master_info '' to hash table
2020-02-13 16:10:31 0 [Note] /usr/sbin/mysqld: ready for connections.
Version: '10.3.22-MariaDB-0+deb10u1' socket: '/run/mysqld/mysqld.sock' port: 3306 Raspbian 10
2020-02-13 16:10:31 0 [Note] InnoDB: Buffer pool(s) load completed at 200213 16:10:31
Nextcloud logs
{"reqId":"rxe9xZTDtfX0z0JGTRF6","level":2,"time":"2020-03-31T13:30:20+00:00","remoteAddr":"","user":"--","app":"appstoreFetcher","method":"","url":"--","message":"Could not connect to appstore: cURL error 28: Operation timed out after 10000 milliseconds with 4154304 out of 4591347 bytes received (see http://curl.haxx.se/libcurl/c/libcurl-errors.html)","userAgent":"--","version":"18.0.3.0"}
Any help is much appreciated. This is my first time setting up Nextcloud on the Raspberry Pi. I am relatively new to using linux commands like sudo and all that as well, so please explain steps thoroughly.
Many thanks in advance!
Best regards
SBC
