is it possible to allow only clients from specific device , recognized bei device Serial, or Mac or better pre created certificate?
I want to keep control with which devices the users syncronize their cloud.
regards
hawk0815
regards
hawk0815
should I laugh about it now???
i have used google befor, You can believe me, but not always you can find what you are looking for!
especially not if you do not know the exact terms. I would have searched this in the settings of Nextcloud and not in Apache.
but no matter
What I have not yet clear, and yes I have been searching for, how do I then set this up for the client under e.g. IOs, there I only see the possibility to enter user name and password!
Hm… Yes
