I’m stuck getting Nextcloud AIO up an running. The Nextcloud container seems to be stuck, as Apache and Notify Push are waiting for it to start:
The Nextcloud container logs the following:
Connection to nextcloud-aio-database (172.19.0.4) 5432 port [tcp/postgresql] succeeded!
+ '[' -n '' ']'
+ set +x
I am running unRAID 6.12.6 and am in the progress of making a new instance of Nextcloud AIO, after having used Nextcloud without AIO for a couple of years now.
Edit: Now the logs also show this:
Configuring Redis as session handler...
The initial Nextcloud installation failed.
Please reset AIO properly and try again. For further clues what went wrong, check the logs above.
See https://github.com/nextcloud/all-in-one#how-to-properly-reset-the-instance
I have followed the reset instructions once already, only to end up at the same issue. The only thing I think I could change at the moment is to change the unRAID Docker storage from an image file to a directory.
