I am trying to install Nextcloud AIO v7.7.1 with docker compose in Ubuntu 23.10.
I have opened port 443 for both UDP & TCP in my router.
portchecker.co is showing the port is open.
But when I try to enter my domain name it keeps saying that port 443 is not reachable.
I have added “SKIP_DOMAIN_VALIDATION=true” to my compose file, but still it doesn’t help:
#Nextcloud AIO stands for Nextcloud All-in-One and provides easy deployment and maintenance with most features included in this one Nextcloud instance
init: true
restart: unless-stopped
volumes:
ports:
- 80:80 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
- 8080:8080
- 8443:8443 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
- NEXTCLOUD_DATADIR=$NCDATA # Allows to set the host directory for Nextcloud's datadir. ⚠️⚠️⚠️ Warning: do not set or adjust this value after the initial Nextcloud installation is done! See https://github.com/nextcloud/all-in-one#how-to-change-the-default-location-of-nextclouds-datadir
- NEXTCLOUD_ENABLE_DRI_DEVICE=true # This allows to enable the /dev/dri device in the Nextcloud container. ⚠️⚠️⚠️ Warning: this only works if the '/dev/dri' device is present on the host! If it should not exist on your host, don't set this to true as otherwise the Nextcloud container will fail to start! See https://github.com/nextcloud/all-in-one#how-to-enable-hardware-transcoding-for-nextcloud
- SKIP_DOMAIN_VALIDATION=true
volumes:
