Nextcloud AIO v10.5.0 ( Hub 9 30.0.5)
Ubuntu 24.04.2 LTS in local network
My local NC AIO seems to be running fine, but I noticed that (suddenly?) the pi-hole interface was no longer reachable at http://192.168.x.x:8573/admin/
The AIO containers interface shows a yellow “(Starting)” status for the pi-hole community container.
Restarting the containers did not fix it. Restarting the OS did not fix it.
Note: pi-hole itself, seems to be running fine but I cannot reach the Web Admin interface…
Looking in the logs I see no strange things.
see Introducing Pi-hole v6 – Pi-hole
lighttpd is disabled, new pihole webserver implemented… could be your cause?
szaimen
February 20, 2025, 11:41am
3
Hi, can you please create a new discussion for this here so that we can track this and dont forget it? Thanks in advance!
@scubamuc @szaimen Indeed: my nextcloud-aio-pihole is v6.0…
This is, obviously, because nextcloud-aio-pihole uses pihole/pihole@latest!
I am unsure what to do at this moment because the community container seems broken? How do I get the new Webserver running?
Should I revert and re-build using a version <6.0, e.g. 2024.07.0?
szaimen
February 20, 2025, 11:50am
5
Please first create a new discussion on github like I mentioned above.
system
Closed
May 21, 2025, 11:31am
8
