Nextcloud version (eg, 20.0.5): 28.0.1
AIO v7.11.2
Operating system and version (eg, Ubuntu 20.04): Linux Mint 21.3
I have installed Nextcloud with the AIO.
In the past is has upgraded on it’s own during the backup process on Saturday.
It does not seem like it wants to update from 28.0.1 to 28.0.2.
I have tried restarting it and that hasn’t helped.
Based on another comment, I tried restoring my last backup and then restarting it twice and that didn’t update either.
- Check version of app
- stop containers in aio and restart
- Check version again and see it it still on 28.0.1
AIO log
Trying to fix docker.sock permissions internally...
Adding internal www-data to group ping
e[0;92mInitial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443e[0m
{"level":"info","ts":1706829918.0635366,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Thu Feb 01 23:25:18.067661 2024] [mpm_event:notice] [pid 116:tid 140695060237128] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Thu Feb 01 23:25:18.067940 2024] [core:notice] [pid 116:tid 140695060237128] AH00094: Command line: 'httpd -D FOREGROUND'
[01-Feb-2024 23:25:18] NOTICE: fpm is running, pid 122
[01-Feb-2024 23:25:18] NOTICE: ready to handle connections
Deleting duplicate sessions
{"level":"info","ts":1706831031.1661623,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Thu Feb 01 23:43:51.321412 2024] [mpm_event:notice] [pid 106:tid 139763804842824] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Thu Feb 01 23:43:51.321453 2024] [core:notice] [pid 106:tid 139763804842824] AH00094: Command line: 'httpd -D FOREGROUND'
[01-Feb-2024 23:43:51] NOTICE: fpm is running, pid 111
[01-Feb-2024 23:43:51] NOTICE: ready to handle connections
{"level":"info","ts":1706831629.1532931,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[01-Feb-2024 23:53:49] NOTICE: fpm is running, pid 113
[01-Feb-2024 23:53:49] NOTICE: ready to handle connections
[Thu Feb 01 23:53:49.259287 2024] [mpm_event:notice] [pid 108:tid 139792130419528] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Thu Feb 01 23:53:49.259733 2024] [core:notice] [pid 108:tid 139792130419528] AH00094: Command line: 'httpd -D FOREGROUND'
{"level":"info","ts":1706831666.4087157,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Thu Feb 01 23:54:26.741564 2024] [mpm_event:notice] [pid 108:tid 139746608024392] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Thu Feb 01 23:54:26.742003 2024] [core:notice] [pid 108:tid 139746608024392] AH00094: Command line: 'httpd -D FOREGROUND'
[01-Feb-2024 23:54:26] NOTICE: fpm is running, pid 113
[01-Feb-2024 23:54:26] NOTICE: ready to handle connections
Deleted Images:
untagged: nextcloud/aio-notify-push@sha256:24324c5739980158bd23a1a797d353a70ba544888f714a4c4e93d8e6ac681df0
deleted: sha256:9e72c6b4f76947ae795ec42806d658baf36d555424b41c8e1d8275bea6fe531d
deleted: sha256:6cb75eaf8517b9f73f6dc3095272c10e6c25396f7f116da48008236074f2758a
deleted: sha256:4d3cb9c8d8e1efaa59e7b1b4ae0add2f05e68c136fd32da593d40814d4e35157
deleted: sha256:8c4692a3573f30d995b3198cf55d569cbb990d7ea75fbe2855864eba2aed090f
untagged: nextcloud/aio-nextcloud@sha256:37768f8d6a4752902c007e169f9bb4d895ed8841035a6f5eb1e1c029793c2ffe
deleted: sha256:c1527f7212672600b174ad73124eccb6112325f452891ab069ad05df547fde83
deleted: sha256:58ac08d56f501c3f541d265a1197ad4250c878419442bdd4d5bcfcde937c9a40
deleted: sha256:5105897de240b0e304a0320f66640595615686f11e5b8b59a718c9b141ef76c5
deleted: sha256:b7c18c9b6ebf60262ee40580ee94af595aa471a89cf7a8fe5a416ef27cf08b85
deleted: sha256:06a77002fad850e1f1b862b4ae3b37e2a8ef238391a25afce8d4bdfd2ca4de84
deleted: sha256:1ae6d1641d075aac5c23063dd37b37009d407ff196597564d1d3de71e652c4e8
deleted: sha256:8a5e5f0d5def16d32261bbbf3f2595962925418518dfab481756623b38b651b9
deleted: sha256:9cccd4e1b0ce9b69944b2c0e47b65e905e19725fd25c61d2781f5874c79472d7
deleted: sha256:94ff706baebb4d15f1ed8f5922f15e68fc130423ddfd8475c875964f06d757b4
deleted: sha256:5f42aa57fd0568f309ca3b20bc4dad754c4a4791f78ff31f397ebf46f0403e5b
deleted: sha256:47f21c45da162338e3316b07a22349392bed8377371bfbc78088a6e55e011b70
deleted: sha256:4c11f61bfab933d0b4e9b49c1ded04ab5e94324248568b9c188f951f3e23c8e0
deleted: sha256:f6e867f3554f3609b622b1a52c136ab23f6750a33e638257f39adc7dd07304fc
deleted: sha256:758ee8a43531b4adedeb5be0b353b2f9cd0dc287263f8fa812edc5397a3fedff
deleted: sha256:e75d0834c357407d6a997402701b7c3a1313f69e86fc18a776f040cc1ac3ec78
untagged: nextcloud/aio-redis@sha256:72714bf7ab8deb237de08b7db792737c4e1f512a72d46b23405d5a0e01c8eb7c
deleted: sha256:c554f45a17a4ff89d7fdc8db05c208be67830f1b780b8a63c0cde05a0fccc624
deleted: sha256:52b4ebba3f1707b5f07deef08d4809ade540f8fa379ed5f0d3121969370a43d7
deleted: sha256:46dbed4967ca0494166a438da19df4d070022ad9b41c7abc4ea8de2fb5a561d8
deleted: sha256:9e0729c383aea08123df15c62c61c64a51e6363b922685ec0798263343c82cb0
deleted: sha256:017caa3b5e254359a9b8b939112212afe7792d7b98048a9ab641c8a3b953bb4f
deleted: sha256:09d3b71b927e4d2291477494ff8bdd56919c6a321c6b34f5c8c228c8016142dc
deleted: sha256:ee05cb8470d054d3990df9a71775b7ea5796c43b7900df63096e6d83ba9d9766
deleted: sha256:d04b9a22611098ad586b82023386226e501a88fb642b7b6522ab8d720f2b9399
deleted: sha256:e038231286dccee31aed0eae11e21c6d6562a4cef3829eb08c4dd18c6ec11ddb
deleted: sha256:a80e8e7915cd087f5a8d872f9d4d15c5f74e295ef07e5e68a2f48686818b52a9
untagged: nextcloud/aio-collabora@sha256:2c4a5a0e4dacbe1eb7612daf810edc79b31c1a4a886abaf06533a358d17bed2b
deleted: sha256:26f0669b9fc1e227b0bf063f2bd469642140cce054715be7ea8ab1345ea69782
deleted: sha256:f15f11ddc0f69fb29c6c6b8baa558dabf6cf1fdebf33cc0695ca3ff51c26e571
deleted: sha256:7be9a229eab26815e430cce22350f7f491046573ce41092be7db5e933ffb3d81
deleted: sha256:f6861d72c48984706fa18af214ab0823aba7f4802cbb576005c48900e393547c
untagged: nextcloud/aio-imaginary@sha256:3d1cb04f90eca6dbbaaed0f773ed092a024b0eca742b73f88f8b010025d3ab9b
deleted: sha256:f5aca02aed79530466b04b09bca724e85708677f97e264db4e53c11193a5eb0d
deleted: sha256:c14462151210297a6c8c27d992a61e14d7e2408d7928c8d429cde6ae233523ad
deleted: sha256:71521293268294dbd6aa4c4b76f0791ffc11ddc3cea296bedc31bcbf8ff16105
untagged: nextcloud/aio-watchtower@sha256:29b42d5b7358ee349f4554e794b6e096ef28a65e750affe93fc1664e1ada3918
deleted: sha256:a08e46defabea0d873d8aeae5e3da754437490f56045b46c2310af35c3055eb2
deleted: sha256:20e008078c1fcc8494801403d094a1d730240cf0b26a5119145a35ffc8a7c9d3
deleted: sha256:9f33448224ed0ca66cef4598ac7d50f867d08c305ec89dd643fc1cd82eb52d63
deleted: sha256:66a8ca9ca99a208195764e125554e6bfd546113dbb70525ab8b5aabdeba8b14f
untagged: nextcloud/aio-apache@sha256:94050ffe697a2a4e922d42ce99c0207bc6207bddde116777097ddef880f0a895
deleted: sha256:043501756ed4f566cb198bd672dbc3ccd87cfdf83d2078a26991f775fa1dbd73
deleted: sha256:8f2cd1e7f6c668d2e468cc2f77bded4cc1d78210c9894df85b0c9e92d3a0af51
deleted: sha256:3f5a3ab0a589f82551247b32ba27c1236c3557c5a8602fe10084b4f28c4c7b6a
deleted: sha256:069938e912dc97c4a7cfb767705c0df22033f3a049072f3ebb5421e434e75b1e
deleted: sha256:50f79d57e95b31abebae8948c86d4a68b9c2023763f39125c1fb43777ff9501b
deleted: sha256:2830dacd618e97c848f9b8fcf09b9bf50d0c05f09893708d9e92f5b0c5375f62
deleted: sha256:55c84033ab24ea173fa9ffbd9063a074c3c930bf0e272f842a15ef2923047dbf
deleted: sha256:90c3a71f257c451e3f6dca989f0bf94b430a23bfdd1e1b63b512af76f27c1dac
untagged: nextcloud/aio-postgresql@sha256:893e057dee52060ac6f465744c91abfd2ab5d2ef7e521bfad357a597133fa98f
deleted: sha256:5cedb5caa1c062108a4f4830a87c414d07bff13466e20d5294eb63a3ff147a50
deleted: sha256:6346ce3641562e911f340c3442b0d823621314ac8fb3ed2162b7ae5867c43b30
deleted: sha256:a3f5c1ad0acbf0257c6b4ca0fef8d2e484f7ce9f4ec0dd6fec5f658bcd0181b8
deleted: sha256:9e0b2428818a8711edcd193eda230a25e7448db176cf3279e6280092651100dd
deleted: sha256:6da78f8719a0c40d744524dac49cff1440ff05ee558be60c12a118b2d405ea83
deleted: sha256:8a2055bf21ab17156c8aa59ba490ee8425ea0eefcfbe5e5365e415c22d140267
deleted: sha256:1575a8afe972840001db4ac0ccad722a909aa4a48542ce436a8c8c746a7e4395
deleted: sha256:961d25f8596c4bfe48f379077b4cd19e5e68f410395ad2897baf510605ad19d4
deleted: sha256:8ea9b733d5170d14c02f132e783c5e5001f568a198450b884c1c29ea25582b73
deleted: sha256:a3e229f57c83eb9993b9c28b987ec0a6fe7de8261e39e9981bb69deca56e3916
deleted: sha256:0dc1602df7505d6bb5875b847ff71c2f4baf8a5f103dafef90972a4c2d2c3f6d
deleted: sha256:3f58360fec721f0c35721bbb1333d774a1460c3f071672589509149e96fa06e6
deleted: sha256:7237e81eb8c178b59fca9edd57bd9a69684579bb6ab9d7794a226818ae854282
deleted: sha256:5af4f8f59b764c64c6def53f52ada809fe38d528441d08d01c206dfb3fc3b691
Total reclaimed space: 2.898GB
Total reclaimed space: 0B
[05-Feb-2024 01:09:06] WARNING: [pool www] child 526617 exited on signal 9 (SIGKILL) after 12.529927 seconds from start
[05-Feb-2024 01:09:06] NOTICE: [pool www] child 526638 started
{"level":"info","ts":1707095704.6144722,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[05-Feb-2024 01:15:05] NOTICE: fpm is running, pid 111
[05-Feb-2024 01:15:05] NOTICE: ready to handle connections
[Mon Feb 05 01:15:05.615017 2024] [mpm_event:notice] [pid 106:tid 140003747773256] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Mon Feb 05 01:15:05.615054 2024] [core:notice] [pid 106:tid 140003747773256] AH00094: Command line: 'httpd -D FOREGROUND'
NOTICE: PHP message: 404 Not Found
Type: Slim\Exception\HttpNotFoundException
4
Message: Not found.
File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
Line: 76
Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(56): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(168): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(115): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(38): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(269): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(199): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(183): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#12 /var/www/docker-aio/php/public/index.php(185): Slim\App->run()
#13 {main}
Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
{"level":"info","ts":1707147861.4279687,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Mon Feb 05 15:44:21.591964 2024] [mpm_event:notice] [pid 105:tid 139805627067208] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Mon Feb 05 15:44:21.592344 2024] [core:notice] [pid 105:tid 139805627067208] AH00094: Command line: 'httpd -D FOREGROUND'
[05-Feb-2024 15:44:21] NOTICE: fpm is running, pid 111
[05-Feb-2024 15:44:21] NOTICE: ready to handle connections
{"level":"info","ts":1707151685.51909,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Mon Feb 05 16:48:05.733891 2024] [mpm_event:notice] [pid 105:tid 140240077556552] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Mon Feb 05 16:48:05.733947 2024] [core:notice] [pid 105:tid 140240077556552] AH00094: Command line: 'httpd -D FOREGROUND'
[05-Feb-2024 16:48:05] NOTICE: fpm is running, pid 110
[05-Feb-2024 16:48:05] NOTICE: ready to handle connections
{"level":"info","ts":1707162300.450546,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Mon Feb 05 19:45:00.534684 2024] [mpm_event:notice] [pid 108:tid 140629814827848] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Mon Feb 05 19:45:00.535717 2024] [core:notice] [pid 108:tid 140629814827848] AH00094: Command line: 'httpd -D FOREGROUND'
[05-Feb-2024 19:45:00] NOTICE: fpm is running, pid 113
[05-Feb-2024 19:45:00] NOTICE: ready to handle connections
4
Message: Not found.
Line: 76
#13 {main}
Deleted Images:
untagged: nextcloud/aio-borgbackup@sha256:dc999a7aa68247ce364140c4a061431022142ecb32e6f0376118e46f5d2a82cf
deleted: sha256:763b157d409c20443f57a7a96a8f4d71ffa4370054538f2b531ec0edcca87e3f
deleted: sha256:273ea41c62cbca87a128bdd17aab82d23929c925a44ca674d11b5ec1c08a5a76
deleted: sha256:f98072b2a03b6d60a4b302b14dbb9aee12ab28ba1afe52a702607f2cb5becb9f
Total reclaimed space: 55.7MB
Restarting cron.sh because daily backup time was set, changed or unset.
++ head -1 /mnt/docker-aio-config/data/daily_backup_time
+ BACKUP_TIME=23:00
+ export BACKUP_TIME
+ export DAILY_BACKUP=1
+ DAILY_BACKUP=1
++ sed -n 2p /mnt/docker-aio-config/data/daily_backup_time
+ '[' '' '!=' automaticUpdatesAreNotEnabled ']'
+ export AUTOMATIC_UPDATES=1
+ AUTOMATIC_UPDATES=1
++ sed -n 3p /mnt/docker-aio-config/data/daily_backup_time
+ '[' '' '!=' successNotificationsAreNotEnabled ']'
+ export SEND_SUCCESS_NOTIFICATIONS=1
+ SEND_SUCCESS_NOTIFICATIONS=1
+ set +x
Daily backup script has started
grep: write error: Broken pipe
Starting mastercontainer update...
(The script might get exited due to that. In order to update all the other containers correctly, you need to run this script with the same settings a second time.)
Waiting for watchtower to stop
Creating daily backup...
Waiting for backup container to stop
Starting and updating containers...
Waiting for the Nextcloud container to start
Sending backup notification...
Daily backup script has finished
+ BACKUP_TIME=23:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=23:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=23:00
+ DAILY_BACKUP=1
+ set +x
{"level":"info","ts":1707407512.4574869,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[08-Feb-2024 15:51:53] NOTICE: fpm is running, pid 114
[08-Feb-2024 15:51:53] NOTICE: ready to handle connections
[Thu Feb 08 15:51:53.195701 2024] [mpm_event:notice] [pid 109:tid 139762102344520] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Thu Feb 08 15:51:53.196106 2024] [core:notice] [pid 109:tid 139762102344520] AH00094: Command line: 'httpd -D FOREGROUND'
+ BACKUP_TIME=23:00
+ DAILY_BACKUP=1
+ set +x
{"level":"info","ts":1707407659.5860062,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Thu Feb 08 15:54:20.443205 2024] [mpm_event:notice] [pid 106:tid 139642166754120] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Thu Feb 08 15:54:20.443424 2024] [core:notice] [pid 106:tid 139642166754120] AH00094: Command line: 'httpd -D FOREGROUND'
[08-Feb-2024 15:54:20] NOTICE: fpm is running, pid 116
[08-Feb-2024 15:54:20] NOTICE: ready to handle connections
+ BACKUP_TIME=23:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=23:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=23:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=23:00
+ DAILY_BACKUP=1
+ set +x
4
Message: Not found.
Line: 76
#13 {main}
