AIO Low disk space warning
    • 31.0.6
    • Ubuntu server 24
    • Nextcloud AIO v11.1.0
Todaz I got a warning from the Nextcloud AIO container, that less than 5 Gb left on the storage where the master container is installed.
BUT when I check my storage space I have 400+GB left.
I’m running my Nextcloud AIO instance on a VM in Proxmox. This VM has a single virtual 1 TB disk. I’m also mounted a network share (mutliple Terrabytes) vie the SMB app in Nextcloud, that is where I store the bulk of my data.
Question
Can I safely ignore this or where can I found ‘ghost’ drive that supposedly filled up?
Thanks!
I’m guessing you’re using NEXTCLOUD_DATADIR? If so, your Nextcloud Server data directory may be located on that larger storage, but your other Docker volumes are not. In this case, the one for nextcloud_aio_mastercontainer.
This is more a general Docker matter and not Nextcloud/AIO specific and there are various approaches. However, there is some general guidance in the AIO README here.
