AIO installation using only one IP address - how?
    • AIO current
    • Ubuntu 22.04 LTS
    • AIO
    • none yet
    • AIO
    • Yes
    • at installation
    • AIO
    • no
Hello, I am trying to follow the AIO instructions to install nextcloud via docker. However, on this server I already have an apache2 running serving other websites. This apache uses a dedicated private address 192.168.123.11 . I issued a separate address 192.168123.112 to use with the AIO nextcloud. I installed using
docker run --init --sig-proxy=false --name nextcloud-aio-mastercontainer --restart always --env APACHE_IP_BINDING=192.168.123.112 --publish 192.168.123.112:443:443 --publish 192.168.123.112:80:80 --publish 192.168.123.112:8080:8080 --publish 192.168.123.112:8443:8443 --volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config --volume /var/run/docker.sock:/var/run/docker.sock:ro ghcr.io/nextcloud-releases/all-in-one:latest
but then I always get “Domaincheck container is not running. This is not expected. Most likely this happened because port 443 is already in use on your server.“
But when the container is stopped, there is no process that uses port 443 on the IP address 192.168.123.112. So I must do something wrong. I see
docker-pr 17507     root    8u  IPv4 109570      0t0  TCP 192.168.123.112:http (LISTEN)
docker-pr 17519     root    8u  IPv4 109586      0t0  TCP 192.168.123.112:https (LISTEN)
docker-pr 17531     root    8u  IPv4 108765      0t0  TCP 192.168.123.112:http-alt (LISTEN)
docker-pr 17543     root    8u  IPv4 108781      0t0  TCP 192.168.123.112:8443 (LISTEN)
after I start the master container, so probably my “run” instruction is wrong as the master container seems to block port 443? How do I issue a run command that just uses the IP 192.168.123.112 and starts all containers correctly ?
Thank you, regards, Jakob
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
With such a setup you will always run into some trouble.
Hi @jcol, please check out all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub
I followed that guide, but I thought I could include a dedicated IP address when setting up so that I can run several instances in parallel using the separate IP address to access the m (instead of using different ports). But from the “multiple instances” documentation, it seems that this is not supported. I am now thinking of going the classical installation way inside a webserver instead of deploying an AIO instance.
If you want to run several instances in parallel using the separate IP address a very good option would be the use of QEMU/KVM. You will have one physical hardware but several VM’s and can have for each of them its own IP Addresses. It works with both classical installation as well as AIO or snap.
IP addresses are not a great way to use web applications like Nextcloud unless you’re only using them locally. But even then, it’s usually much nicer to have a domain name instead of having to remember IP addresses.
And yes, AIO doesn’t really support using IP addresses. The main reason is that AIO requires a valid TLS certificate, and you can’t obtain publicly trusted certificates for local IP addresses.
With a manual installation, you can use self-signed certificates or even no TLS at all. However, the former will result in browser warnings and potential issues with certain mobile apps and operating systems, while the latter is generally not recommended (even in a LAN, in my opinion), since everything is transmitted unencrypted.
My recommendation would therefore be to use a public domain name. That way, you can run as many instances as you like on the same local (or public) IP, and the web server/reverse proxy will route requests via Server Name Indication (SNI), i.e., based on the URL (e.g., cloud1.yourdomain.tld, cloud2.yourdomain.tld, etc.) to the correct instance.
Another advantage of this would be that you can use Let’s Encrypt certificates, which are automatically trusted by all browsers and operating systems.
By the way, using a public domain doesn’t necessarily mean your instances have to be exposed to the internet. See here: https://github.com/nextcloud/all-in-one/blob/main/local-instance.md#3-use-the-acme-dns-challenge
