AIO: External storage (Local) on SMB bind mount – user data still written to Docker volume
I’m running Nextcloud All-In-One (AIO) behind NGINX Proxy Manager in Docker and I’m trying to use an SMB share as primary user storage to avoid filling up the Docker host disk.
I have mounted the SMB share on the host and bind-mounted it into the AIO mastercontainer. I also enabled the External Storage app and configured a Local external storage backend.
However, user data is still written to the Docker volume instead of the SMB share.
I want to confirm whether my approach is supported in AIO and what the correct procedure is.
What I’ve done
Mounted SMB on the host, for example:
/mnt/next-cloud
Bind-mounted it into the AIO mastercontainer:
volumes:
  • /mnt/next-cloud:/mnt/next-cloud
Enabled External Storage:
occ app:enable files_external
occ config:system:set files_external_allow_create_new_local --value=true --type=boolean
Added External storage → Local with path:
/mnt/next-cloud/users
Set it as default backend:
occ config:system:set files_external_default --value=“users”
Verified the mount is visible inside the container:
ls -la /mnt/next-cloud
Logged out and back in.
Expected behavior
User home directories should be created under:
/mnt/next-cloud/users/
Disk usage should grow on the SMB share, not in /var/lib/docker.
Actual behavior
/mnt/next-cloud/users remains empty
User uploads still increase Docker disk usage
occ files:scan either does nothing or fails with Redis disconnects during scans
Hi, see GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.
External Storage !== Primary Storage
I’d like to thank you for replying to my post it helped me find the exact option I need for my setup
