AiO Apache & Caddy not starting
    • 13.2.1
    • Unraid 7.3.1
    • 13.2.1
    • 2.15.1
    • replace me
    • yes
    • Couple weeks ago
    Installation method (e.g. AlO, NCP, Bare Metal/Archive, etc.)
    • Unraid community app
    • Cloudflare
  • Summary of the issue you are facing:
Nextcloud Apache and Caddy not starting
Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.290988627Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290989867Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290991087Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290992307Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:33.290993507Z #31 {main}
2026-06-22T19:48:33.290994627Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:33.788056917Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:33.788081917Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:33.788084617Z Code: 404
2026-06-22T19:48:33.788093377Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:33.788106467Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:33.788116307Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:33.788117937Z Line: 115
2026-06-22T19:48:33.788119227Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:33.788121227Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:33.788123077Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:33.788124327Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:33.788126137Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:33.788127937Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:33.788129407Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.788131127Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:33.788132977Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.788134487Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:33.788135997Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:33.788138367Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:33.788140257Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:33.788141817Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.788154717Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.788156637Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788159737Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788162257Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788164017Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788165367Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788167057Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:33.788168927Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788170417Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.788172097Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788174017Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.788175937Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788177187Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.788179037Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788180807Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788182117Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788183837Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:33.788185577Z #31 {main}
2026-06-22T19:48:33.788186687Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:33.966642317Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:33.966661197Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:33.966669127Z Code: 404
2026-06-22T19:48:33.966679547Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:33.966681137Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:33.966682727Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:33.966683987Z Line: 115
2026-06-22T19:48:33.966685137Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:33.966686587Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:33.966687887Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:33.966689147Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:33.966690487Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:33.966691747Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:33.966693137Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.966694667Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:33.966696007Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.966697247Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:33.966698477Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:33.966700467Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:33.966701827Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:33.966703047Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.966704437Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.966707017Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966709037Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966710277Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966711727Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966713017Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966714257Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:33.966715587Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966716867Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.966718207Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966719577Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.966720957Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966722207Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.966723507Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966724737Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966725957Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966727177Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:33.966728367Z #31 {main}
2026-06-22T19:48:33.966729487Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:34.450049807Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:34.450080877Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:34.450092177Z Code: 404
2026-06-22T19:48:34.450093567Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:34.450095667Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:34.450097017Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:34.450098247Z Line: 115
2026-06-22T19:48:34.450099367Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:34.450100897Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:34.450102177Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:34.450103487Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:34.450104747Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:34.450106067Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:34.450111487Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:34.450112867Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:34.450114267Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:34.450115507Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:34.450116737Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:34.450118667Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:34.450120037Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:34.450121307Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:34.450122737Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:34.450125347Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450127558Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450128808Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450130028Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450131298Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450132548Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:34.450134418Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450135718Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:34.450137088Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450138468Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:34.450139918Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450141268Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:34.450142648Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450143898Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450145108Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450146348Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:34.450147538Z #31 {main}
2026-06-22T19:48:34.450148658Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:39.025945473Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:39.025962163Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:39.025964333Z Code: 404
2026-06-22T19:48:39.025965723Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:39.025967803Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:39.025969173Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:39.025970413Z Line: 115
2026-06-22T19:48:39.025971633Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:39.025973083Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:39.025974393Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:39.025975663Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:39.025976943Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:39.025978203Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:39.025979533Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:39.025980833Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:39.025982133Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:39.025983363Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:39.025984593Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:39.025986173Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:39.025987513Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:39.025988753Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:39.025990173Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:39.025995463Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.025998243Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.025999853Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026001253Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026002573Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026003873Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:39.026005243Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026006613Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:39.026008003Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026009453Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:39.026010863Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026012193Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:39.026013553Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026014843Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026016113Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026017403Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:39.026018663Z #31 {main}
2026-06-22T19:48:39.026019853Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:50:35.541430629Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:50:35.541454359Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:50:35.541457039Z Code: 404
2026-06-22T19:50:35.541458419Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:50:35.541460449Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:50:35.541461729Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:50:35.541462869Z Line: 115
2026-06-22T19:50:35.541463919Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:50:35.541465279Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:50:35.541466499Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:50:35.541467669Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:50:35.541469059Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:50:35.541472029Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:50:35.541473279Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:50:35.541474519Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:50:35.541475739Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:50:35.541476909Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:50:35.541478149Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:50:35.541479849Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:50:35.541481169Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:50:35.541482589Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:50:35.541489549Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:50:35.541506809Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541508259Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541509479Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541510649Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541511919Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541513129Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:50:35.541514419Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541515669Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:50:35.541516979Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541518309Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:50:35.541519639Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541520859Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:50:35.541522129Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541523409Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541524609Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541525799Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:50:35.541526949Z #31 {main}
2026-06-22T19:50:35.541528009Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:51:49.354217947Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:51:49.354242957Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:51:49.354246157Z Code: 404
2026-06-22T19:51:49.354248047Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:51:49.354250777Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:51:49.354252617Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:51:49.354254547Z Line: 115
2026-06-22T19:51:49.354255657Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:51:49.354257577Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:51:49.354259347Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:51:49.354260527Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:51:49.354262597Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:51:49.354264317Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:51:49.354265767Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:51:49.354267357Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:51:49.354269137Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:51:49.354270397Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:51:49.354272007Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:51:49.354274437Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:51:49.354276247Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:51:49.354277407Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:51:49.354291827Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:51:49.354305787Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354307647Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354309057Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354310557Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354312287Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354313527Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:51:49.354315287Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354317067Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:51:49.354318467Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354320227Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:51:49.354322067Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354323517Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:51:49.354325057Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354326787Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354328037Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:51:49.354329657Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:51:49.354333517Z #31 {main}
2026-06-22T19:51:49.354336697Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T20:10:54.765786407Z NOTICE: PHP message: Slim Application Error
2026-06-22T20:10:54.765800058Z Type: Exception
2026-06-22T20:10:54.765802588Z Code: 0
2026-06-22T20:10:54.765803928Z Message: Could not create container nextcloud-aio-apache: {"message":"layer does not exist"}
2026-06-22T20:10:54.765805388Z File: /var/www/docker-aio/php/src/Docker/DockerActionManager.php
2026-06-22T20:10:54.765806608Z Line: 506
2026-06-22T20:10:54.765807708Z Trace: #0 /var/www/docker-aio/php/src/Controller/DockerController.php(44): AIO\Docker\DockerActionManager->CreateContainer(Object(AIO\Container\Container))
2026-06-22T20:10:54.765809228Z #1 /var/www/docker-aio/php/src/Controller/DockerController.php(269): AIO\Controller\DockerController->PerformRecursiveContainerStart('nextcloud-aio-a...', true, Object(Closure))
2026-06-22T20:10:54.765810578Z #2 /var/www/docker-aio/php/src/Controller/DockerController.php(250): AIO\Controller\DockerController->startTopContainer(true, Object(Closure))
2026-06-22T20:10:54.765811948Z #3 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->StartContainer(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T20:10:54.765813638Z #4 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T20:10:54.765815068Z #5 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765816358Z #6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765817598Z #7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765818778Z #8 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765820018Z #9 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765821248Z #10 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T20:10:54.765823308Z #11 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765824588Z #12 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:10:54.765825908Z #13 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765831228Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:10:54.765838018Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765839378Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:10:54.765840678Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765841918Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765843198Z #19 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T20:10:54.765844408Z #20 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T20:10:54.765845618Z #21 {main}
2026-06-22T20:10:54.765846738Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T20:12:09.984988864Z NOTICE: PHP message: Slim Application Error
2026-06-22T20:12:09.985010254Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T20:12:09.985012854Z Code: 404
2026-06-22T20:12:09.985014214Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T20:12:09.985016094Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T20:12:09.985017624Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T20:12:09.985018824Z Line: 115
2026-06-22T20:12:09.985019884Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T20:12:09.985021294Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T20:12:09.985022624Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T20:12:09.985023804Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T20:12:09.985024984Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T20:12:09.985031774Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T20:12:09.985042874Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T20:12:09.985044244Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T20:12:09.985045544Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T20:12:09.985046744Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T20:12:09.985047954Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T20:12:09.985049964Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T20:12:09.985051274Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T20:12:09.985052464Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T20:12:09.985053814Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T20:12:09.985055114Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985056334Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985057524Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985058754Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985059944Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985061144Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T20:12:09.985062444Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985063654Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:12:09.985066344Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985069084Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:12:09.985070484Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985071714Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:12:09.985073014Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985074254Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985075454Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:09.985076674Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T20:12:09.985077864Z #31 {main}
2026-06-22T20:12:09.985078964Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T20:12:11.390888305Z NOTICE: PHP message: Slim Application Error
2026-06-22T20:12:11.390911555Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T20:12:11.390914385Z Code: 404
2026-06-22T20:12:11.390916235Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T20:12:11.390918755Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T20:12:11.390920635Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T20:12:11.390922325Z Line: 115
2026-06-22T20:12:11.390923485Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T20:12:11.390925465Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T20:12:11.390927275Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T20:12:11.390928505Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T20:12:11.390937985Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T20:12:11.390951625Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T20:12:11.390953485Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T20:12:11.390954875Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T20:12:11.390956685Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T20:12:11.390958445Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T20:12:11.390959675Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T20:12:11.390962165Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T20:12:11.390964005Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T20:12:11.390965755Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T20:12:11.390967265Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T20:12:11.390968985Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390970765Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390972185Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390973715Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390975475Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390976795Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T20:12:11.390978535Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390980325Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:12:11.390983425Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390986135Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:12:11.390988024Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390989794Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T20:12:11.390991114Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390992814Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390994544Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T20:12:11.390995754Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T20:12:11.390997474Z #31 {main}
2026-06-22T20:12:11.390999164Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
PASTE
PASTE HERE
PASTE HERE
Hello @Luke_Bower, welcome to the Nextcloud community! :handshake:
the error
is quite clear.. AiO is expected to create all of the container itself - often runing docker compose down and docker compose up (or the Unraid equivavalent) helps already. if not please collect mastercontainer logs and share. review existing topics AiO is widely used and many topics with troubleshooting instructions exist already.
After updating Nextcloud or this a first-time install of Nextcloud?
There are multiple Nextcloud apps on Unraid but I assume you’re referring to this one?
If so, post your config values + take note of the user defined networking note on the store page.
Ha! I wish it had been this easy. On the AIO Web ui, I’ve stopped and started the containers, which is how this module is doing docker compose pull and docker compose up. I’ve also stopped it, run docker compose prune, deleted any old containers aside from the master, then restarted it and made it pull everything from fresh while still getting the same error.
Logs:
2026-06-22T19:48:15.203171445Z Trying to fix docker.sock permissions internally...
2026-06-22T19:48:15.205215469Z Creating docker group internally with id 281
2026-06-22T19:48:15.962949683Z WARNING: No swap limit support
2026-06-22T19:48:15.972419314Z WARNING: No swap limit support
2026-06-22T19:48:16.105378920Z e[0;31mThe environmental variable TZ has been set which is not supported by AIO since it only supports running in the default Etc/UTC timezone!e[0m
2026-06-22T19:48:16.105399710Z The correct timezone can be set in the AIO interface later on!
2026-06-22T19:48:16.109193838Z e[0;92mInitial startup of Nextcloud All-in-One complete!
2026-06-22T19:48:16.109207678Z You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
2026-06-22T19:48:16.109210328Z E.g. https://internal.ip.of.this.server:8080
2026-06-22T19:48:16.109212278Z ⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
2026-06-22T19:48:16.109214578Z
2026-06-22T19:48:16.109216238Z If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
2026-06-22T19:48:16.109217468Z https://your-domain-that-points-to-this-server.tld:8443e[0m
2026-06-22T19:48:17.220903087Z ++ head -1 /mnt/docker-aio-config/data/daily_backup_time
2026-06-22T19:48:17.221203778Z + BACKUP_TIME=04:00
2026-06-22T19:48:17.221227588Z + export BACKUP_TIME
2026-06-22T19:48:17.221231408Z + export DAILY_BACKUP=1
2026-06-22T19:48:17.221233668Z + DAILY_BACKUP=1
2026-06-22T19:48:17.221389878Z ++ sed -n 2p /mnt/docker-aio-config/data/daily_backup_time
2026-06-22T19:48:17.221642859Z + '[' '' '!=' automaticUpdatesAreNotEnabled ']'
2026-06-22T19:48:17.221646199Z + export AUTOMATIC_UPDATES=1
2026-06-22T19:48:17.221647469Z + AUTOMATIC_UPDATES=1
2026-06-22T19:48:17.221820089Z ++ sed -n 3p /mnt/docker-aio-config/data/daily_backup_time
2026-06-22T19:48:17.222079340Z + '[' '' '!=' successNotificationsAreNotEnabled ']'
2026-06-22T19:48:17.222083120Z + export SEND_SUCCESS_NOTIFICATIONS=1
2026-06-22T19:48:17.222084400Z + SEND_SUCCESS_NOTIFICATIONS=1
2026-06-22T19:48:17.222100850Z + '[' warn '!=' debug ']'
2026-06-22T19:48:17.222102750Z + set +x
2026-06-22T19:48:17.239618557Z [22-Jun-2026 19:48:17] NOTICE: fpm is running, pid 239
2026-06-22T19:48:17.239631687Z [22-Jun-2026 19:48:17] NOTICE: ready to handle connections
2026-06-22T19:48:30.428892129Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:30.428906799Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:30.428909059Z Code: 404
2026-06-22T19:48:30.428910419Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:30.428918229Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:30.428925289Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:30.428926669Z Line: 115
2026-06-22T19:48:30.428927829Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:30.428929279Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:30.428930589Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:30.428932469Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:30.428933919Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:30.428935229Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:30.428936589Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:30.428937939Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:30.428939239Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:30.428940479Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:30.428941729Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:30.428943659Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:30.428945009Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:30.428946249Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:30.428947659Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:30.428949019Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428959429Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428961519Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428962799Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428964079Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428965329Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:30.428966669Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428967969Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:30.428969329Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428970709Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:30.428972069Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428973329Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:30.428974659Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428975909Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428977139Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:30.428978379Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:30.428980559Z #31 {main}
2026-06-22T19:48:30.428981699Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:33.290905227Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:33.290923337Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:33.290925567Z Code: 404
2026-06-22T19:48:33.290926957Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:33.290935727Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:33.290945877Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:33.290947157Z Line: 115
2026-06-22T19:48:33.290948287Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:33.290949807Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:33.290951097Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:33.290952347Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:33.290953617Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:33.290956707Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:33.290958047Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.290959327Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:33.290960607Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.290961847Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:33.290963087Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:33.290965087Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:33.290966417Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:33.290967657Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.290969057Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.290970467Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290973317Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290975347Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290976617Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290977917Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290979217Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:33.290980537Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290981807Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.290983157Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290984677Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.290986067Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290987327Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.290988627Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290989867Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290991087Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.290992307Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:33.290993507Z #31 {main}
2026-06-22T19:48:33.290994627Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:33.788056917Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:33.788081917Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:33.788084617Z Code: 404
2026-06-22T19:48:33.788093377Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:33.788106467Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:33.788116307Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:33.788117937Z Line: 115
2026-06-22T19:48:33.788119227Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:33.788121227Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:33.788123077Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:33.788124327Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:33.788126137Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:33.788127937Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:33.788129407Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.788131127Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:33.788132977Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.788134487Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:33.788135997Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:33.788138367Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:33.788140257Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:33.788141817Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.788154717Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.788156637Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788159737Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788162257Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788164017Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788165367Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788167057Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:33.788168927Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788170417Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.788172097Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788174017Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.788175937Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788177187Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.788179037Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788180807Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788182117Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.788183837Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:33.788185577Z #31 {main}
2026-06-22T19:48:33.788186687Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:33.966642317Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:33.966661197Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:33.966669127Z Code: 404
2026-06-22T19:48:33.966679547Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:33.966681137Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:33.966682727Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:33.966683987Z Line: 115
2026-06-22T19:48:33.966685137Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:33.966686587Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:33.966687887Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:33.966689147Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:33.966690487Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:33.966691747Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:33.966693137Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.966694667Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:33.966696007Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:33.966697247Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:33.966698477Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:33.966700467Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:33.966701827Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:33.966703047Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.966704437Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:33.966707017Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966709037Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966710277Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966711727Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966713017Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966714257Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:33.966715587Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966716867Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.966718207Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966719577Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.966720957Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966722207Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:33.966723507Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966724737Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966725957Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:33.966727177Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:33.966728367Z #31 {main}
2026-06-22T19:48:33.966729487Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:34.450049807Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:34.450080877Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:34.450092177Z Code: 404
2026-06-22T19:48:34.450093567Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:34.450095667Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:34.450097017Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:34.450098247Z Line: 115
2026-06-22T19:48:34.450099367Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:34.450100897Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:34.450102177Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:34.450103487Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:34.450104747Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:34.450106067Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:34.450111487Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:34.450112867Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:34.450114267Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:34.450115507Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:34.450116737Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:34.450118667Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:34.450120037Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:34.450121307Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:34.450122737Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:34.450125347Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450127558Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450128808Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450130028Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450131298Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450132548Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:34.450134418Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450135718Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:34.450137088Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450138468Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:34.450139918Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450141268Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:34.450142648Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450143898Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450145108Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:34.450146348Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:34.450147538Z #31 {main}
2026-06-22T19:48:34.450148658Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:48:39.025945473Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:48:39.025962163Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:48:39.025964333Z Code: 404
2026-06-22T19:48:39.025965723Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:48:39.025967803Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:48:39.025969173Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:48:39.025970413Z Line: 115
2026-06-22T19:48:39.025971633Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:48:39.025973083Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:48:39.025974393Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:48:39.025975663Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:48:39.025976943Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:48:39.025978203Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:48:39.025979533Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:39.025980833Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:48:39.025982133Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:48:39.025983363Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:48:39.025984593Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:48:39.025986173Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:48:39.025987513Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:48:39.025988753Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:39.025990173Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:48:39.025995463Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.025998243Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.025999853Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026001253Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026002573Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026003873Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:48:39.026005243Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026006613Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:39.026008003Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026009453Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:39.026010863Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026012193Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:48:39.026013553Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026014843Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026016113Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:48:39.026017403Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:48:39.026018663Z #31 {main}
2026-06-22T19:48:39.026019853Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:50:35.541430629Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:50:35.541454359Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:50:35.541457039Z Code: 404
2026-06-22T19:50:35.541458419Z Message: Client error: `GET http://127.0.0.1/v1.44/containers/nextcloud-aio-apache/logs?stdout=true&stderr=true&timestamps=true&since=` resulted in a `404 Not Found` response:
2026-06-22T19:50:35.541460449Z {"message":"No such container: nextcloud-aio-apache"}
2026-06-22T19:50:35.541461729Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2026-06-22T19:50:35.541462869Z Line: 115
2026-06-22T19:50:35.541463919Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2026-06-22T19:50:35.541465279Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2026-06-22T19:50:35.541466499Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2026-06-22T19:50:35.541467669Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2026-06-22T19:50:35.541469059Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2026-06-22T19:50:35.541472029Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2026-06-22T19:50:35.541473279Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:50:35.541474519Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2026-06-22T19:50:35.541475739Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2026-06-22T19:50:35.541476909Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(229): GuzzleHttp\Promise\Promise->wait()
2026-06-22T19:50:35.541478149Z #10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(1130): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2026-06-22T19:50:35.541479849Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(178): AIO\Docker\DockerActionManager->sendHttpRequest('GET', 'http://127.0.0....')
2026-06-22T19:50:35.541481169Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(76): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-a...', '')
2026-06-22T19:50:35.541482589Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:50:35.541489549Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(Slim\Psr7\Request), Object(Slim\Psr7\Response), Array)
2026-06-22T19:50:35.541506809Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541508259Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541509479Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541510649Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541511919Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541513129Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(Slim\Psr7\Request), Object(Slim\Routing\RouteRunner))
2026-06-22T19:50:35.541514419Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541515669Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:50:35.541516979Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(54): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541518309Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:50:35.541519639Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541520859Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Psr7\Request), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2026-06-22T19:50:35.541522129Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541523409Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541524609Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(Slim\Psr7\Request))
2026-06-22T19:50:35.541525799Z #30 /var/www/docker-aio/php/public/index.php(284): Slim\App->run()
2026-06-22T19:50:35.541526949Z #31 {main}
2026-06-22T19:50:35.541528009Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2026-06-22T19:51:49.354217947Z NOTICE: PHP message: Slim Application Error
2026-06-22T19:51:49.354242957Z Type: GuzzleHttp\Exception\ClientException
2026-06-22T19:51:49.354246157Z Code: 404
After it updated at some point. I’ve had nextcloud working for a couple of months.
Yep.
Here’s the config.
Yes, UDN is on.
tells us both containers don’t exist.. which matches your screenshot which in fact doesn’t show apache and caddy containers - but other AiO containers are fine.. on the unraid do you see any errors while downloading/creating apache and caddy containers?
sounds similar to Containers doesn't start after update · nextcloud/all-in-one · Discussion #7742 · GitHub plz double check troubleshooting steps..
Hi, we have pushed a fix for the reported problem in aio-interface: fix nginx reverse proxy read timeout blocks AIO from starting consecutive containers by Copilot · Pull Request #8016 · nextcloud/all-in-one · GitHub which is now released with AIO v13.3.0 Beta. Testing and feedback is welcome! See GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance. · GitHub
I just tried the Beta, and it seems to be significantly worse. Now multiple containers won’t start, and it will never finish pulling the Nextcloud Talk container.
Now, Apache & Caddy, Nextcloud, and client push sit at “starting”
I can’t easily post logs because I’m only allowed to post 4 links in a post and there’s apparently a lot of links in the log
Hm. This is weird. Do you run a reverse proxy in front of the aio interface? If so can you post its configuration here?
So after the next beta release that updated yesterday, restoring from a backup, prune the docker containers, and then starting and reinstalling/updating the containers, it is FINALLY back up.
A reverse proxy does run on a VM with NGINX, but this never seemed to be the problem. Just the containers seem to keep getting bad updates or are erroring out for some bizarre reason. The most recent beta has fixed it, though.
