AIO 32.03 and Group Folders - file loss
We have used Next Cloud and Group folders for some years. However, I have just built a new server (AIO 32.03) and noticed some commentary about file loss with Group folders, however I have been unable to find any definitive comments about this - is it a real/not real/fixed issue? Is Group Folders safe / reliable to use in the current version of AIO?
Marcus
There is a longer issue at github about file deletions:
They found an issue that was fixed with the latest version 20.1.6, but there is no clear feedback yet if it was solved for everybody.
Thank you for point this out. I guess if it is fixed, it is safe?
If it is the only bug, then yes. I’d always check a bit for myself and certainly keep good backups in case something happens.
