I’m using Raspberry with NC 14.0.4 and Apache2
- Dein Web-Server ist nicht richtig eingerichtet um “/.well-known/caldav” aufzulösen. Weitere Informationen findest Du in der Dokumentation.
- Dein Web-Server ist nicht richtig eingerichtet um “/.well-known/carddav” aufzulösen. Weitere Informationen findest Du in der Dokumentation.
I have this Links found in forum and read
My NC is located in /var/www/html/nextcloud
In the following files I have made changes to the above notes
/var/www/html/nextcloud/.htaccess
/etc/apache2/sites-available/000-default.conf
/etc/apache2/sites-available/default-ssl.conf
/etc/apache2/apache2.conf
a solution was not there
There seems to be many solutions for different Nextcloud Server installations.
It often makes sense to further specify the above warnings.
Thank you for your answers
