Conversations are gone after upgrade to v29.0.0
Nextcloud version: 29.0.0
Operating system and version: Ubuntu 22.04 LTS server
nginx version: 1.18.0
PHP version: 8.1
Is this the first time you’ve seen this error?: Y
- Upgrade from v28 to v29.0.0
root@nextcloud:/var/www/html/nextcloud# sudo -u www-data php ./occ upgrade
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
Setting log level to debug
Turned on maintenance mode
Updating database schema
Updated database
Disabled incompatible app: appointments
Disabled incompatible app: deck
Disabled incompatible app: external
Disabled incompatible app: mail_roundcube
Disabled incompatible app: maps
Disabled incompatible app: quicknotes
Disabled incompatible app: richdocuments
Disabled incompatible app: spreed
Disabled incompatible app: tasks
Disabled incompatible app: user_usage_report
Disabled incompatible app: workflow_kitinerary
Updating <federation> ...
Updated <federation> to 1.19.0
Updating <lookup_server_connector> ...
Updated <lookup_server_connector> to 1.17.0
Updating <oauth2> ...
Updated <oauth2> to 1.17.0
Updating <password_policy> ...
Updated <password_policy> to 1.19.0
Updating <photos> ...
Updated <photos> to 2.5.0
Updating <files> ...
Updated <files> to 2.1.0
Updating <activity> ...
Updated <activity> to 2.21.1
Updating <circles> ...
Updated <circles> to 29.0.0-dev
Updating <cloud_federation_api> ...
Updated <cloud_federation_api> to 1.12.0
Updating <dav> ...
Fix broken values of calendar objects
Done
0/0 [->--------------------------] 0%
Clean up old calendar subscriptions from deleted users that were not cleaned-up
Done
1/1 [============================] 100%
Updated <dav> to 1.30.1
Updating <files_sharing> ...
Done
0/0 [----------->----------------] 0%
Done
Updated <files_sharing> to 1.21.0
Updating <files_trashbin> ...
Updated <files_trashbin> to 1.19.0
Updating <files_versions> ...
Updated <files_versions> to 1.22.0
Updating <sharebymail> ...
Updated <sharebymail> to 1.19.0
Updating <workflowengine> ...
Done
0/0 [------------------>---------] 0%
Done
Updated <workflowengine> to 2.11.0
Updating <admin_audit> ...
Updated <admin_audit> to 1.19.0
Updating <comments> ...
Updated <comments> to 1.19.0
Updating <firstrunwizard> ...
Updated <firstrunwizard> to 2.18.0
Updating <logreader> ...
Updated <logreader> to 2.14.0
Updating <nextcloud_announcements> ...
Updated <nextcloud_announcements> to 1.18.0
Updating <notifications> ...
Updated <notifications> to 2.17.0
Updating <systemtags> ...
Updated <systemtags> to 1.19.0
Updating <theming> ...
Done
0/0 [-------------------------->-] 0%
Done
Updated <theming> to 2.4.0
Updating <contactsinteraction> ...
Updated <contactsinteraction> to 1.10.0
Updating <dashboard> ...
Updated <dashboard> to 7.9.0
Updating <federatedfilesharing> ...
Updated <federatedfilesharing> to 1.19.0
Updating <files_pdfviewer> ...
Updated <files_pdfviewer> to 2.10.0
Updating <files_reminders> ...
Updated <files_reminders> to 1.2.0
Updating <privacy> ...
Updated <privacy> to 1.13.0
Updating <provisioning_api> ...
Updated <provisioning_api> to 1.19.0
Updating <recommendations> ...
Updated <recommendations> to 2.1.0
Updating <related_resources> ...
Updated <related_resources> to 1.4.0
Updating <serverinfo> ...
Updated <serverinfo> to 1.19.0
Updating <settings> ...
Updated <settings> to 1.12.0
Updating <support> ...
Done
0/0 [----->----------------------] 0%
Done
Updated <support> to 1.12.0
Updating <survey_client> ...
Done
0/0 [------------->--------------] 0%
Done
Updated <survey_client> to 1.17.0
Updating <text> ...
Done
0/0 [-------------------->-------] 0%
Done
Updated <text> to 3.10.0
Updating <twofactor_backupcodes> ...
Done
0/0 [>---------------------------] 0%
Done
Updated <twofactor_backupcodes> to 1.18.0
Updating <updatenotification> ...
Updated <updatenotification> to 1.19.1
Updating <user_status> ...
Updated <user_status> to 1.9.0
Updating <viewer> ...
Updated <viewer> to 2.3.0
Updating <weather_status> ...
Updated <weather_status> to 1.9.0
Update app contacts from App Store
Update app deck from App Store
Update app external from App Store
Done
0/0 [------->--------------------] 0%
Done
Done
0/0 [-------------->-------------] 0%
Done
Done
0/0 [---------------------->-----] 0%
Done
Update app richdocuments from App Store
Done
Done
Update app spreed from App Store
Done
0/0 [--------->------------------] 0%
Done
Done
0/0 [---------------->-----------] 0%
Done
Done
0/0 [------------------------>---] 0%
Done
Done
0/0 [--->------------------------] 0%
Done
Done
Done
Starting code integrity check...
Finished code integrity check
Update successful
Turned off maintenance mode
Resetting log level
