i updated my nextcloud to NC19. When i try to load the page i get a basic authentication window. In the nextcloud log i can see a failed login. the url shows https://cloud.doamin.com/index.php
i can login to the instance when i change the url to https://cloud.doamin.com/login
under NC18 it was working fine.
Nextcloud version (eg, 18.0.2):19.0.0
Operating system and version (eg, Ubuntu 20.04): CentOS7
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.6
PHP version (eg, 7.1):PHP 7.4.6
Logon page not loaded
- Update Nextcloud to Nextcloud 19 (Fresh installation also affected)
- Load File
Error lib ResourceLocator can not find a web root (root: /var/www/html/nextcloudapps/spreed, file: css/spreed/8bde-2fe1-merged-files.css?v=b09f21747943fghg44605d8d03, webRoot: , throw: true) 2020-06-14T13:27:00+0200
Error lib ResourceLocator can not find a web root (root: /var/www/html/nextcloudapps/spreed, file: css/spreed/8bde-2fe1-merged-files.css?v=b09f21747bbrr444g3s5d8d03, webRoot: , throw: true) 2020-06-14T12:24:36+0200
Error PHP fread(): read of 8192 bytes failed with errno=21 Is a directory at /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Encryption.php#861 2020-06-14T11:22:49+0200
Error lib ResourceLocator can not find a web root (root: /var/www/html/nextcloudapps/spreed, file: css/spreed/8bde-2fe1-merged-files.css?v=b09f217433rff343e825605d8d03, webRoot: , throw: true) 2020-06-14T11:17:53+0200
Error lib ResourceLocator can not find a web root (root: /var/www/html/nextcloudapps/spreed, file: css/spreed/8bde-2fe1-merged-files.css?v=b09f2174rergrgrgrg7e825605d8d03, webRoot: , throw: true) 2020-06-14T11:17:50+0200
Error lib ResourceLocator can not find a web root (root: /var/www/html/nextcloudapps/spreed, file: css/spreed/8bde-2fe1-merged-files.css?v=b09vfrgt5910a3025ab7e825605d8d03, webRoot: , throw: true) 2020-06-14T11:17:48+0200
Error lib ResourceLocator can not find a web root (root: /var/www/html/nextcloudapps/spreed, file: css/spreed/8bde-2fe1-merged-files.css?v=b09f21747efefe33rd825605d8d03, webRoot: , throw: true) 2020-06-14T11:17:47+0200
'updatechecker' => false,
'instanceid' => '1234',
'passwordsalt' => 'SaltisCool',
'secret' => 'ihavenosecret',
0 => 'cloud.domain.de',
'datadirectory' => '/var/www/html/nextclouddata/data',
'overwrite.cli.url' => 'https://cloud.domain.de',
'version' => '19.0.0.12',
'dbname' => 'clouddatabase',
'dbhost' => 'localhost',
'dbtableprefix' => 'nx_',
'dbuser' => 'clouduser',
'dbpassword' => 'Passwordisnotcool',
'logtimezone' => 'UTC',
'default_language' => 'de',
'mail_smtpmode' => 'sendmail',
'mail_domain' => 'domain.de',
'appstoreenabled' => true,
'appcodechecker' => true,
'appstore.experimental.enabled' => true,
'apps_paths' =>
0 =>
'path' => '/var/www/html/nextcloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/www/html/nextcloudapps',
'url' => '/apps2',
'writable' => true,
'loglevel' => 2,
'theme' => '',
'activity_expire_days' => 1.4141414141413999E+27,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\Image',
1 => 'OC\\Preview\\MP3',
2 => 'OC\\Preview\\TXT',
3 => 'OC\\Preview\\MarkDown',
4 => 'OC\\Preview\\Epub',
5 => 'OC\\Preview\\PDF',
6 => 'OC\\Preview\\OpenDocument',
7 => 'OC\\Preview\\StarOffice',
8 => 'OC\\Preview\\MSOfficeDoc',
9 => 'OC\\Preview\\MSOffice2003',
10 => 'OC\\Preview\\MSOffice2007',
'app_install_overwrite' =>
0 => 'keeweb',
1 => 'drawio',
2 => 'gpxedit',
3 => 'gpxmotion',
4 => 'files_opds',
5 => 'maps',
6 => 'calendar',
7 => 'contacts',
8 => 'deck',
9 => 'circles',
10 => 'ransomware_detection',
11 => 'ocr',
12 => 'timetracker',
13 => 'twofactor_webauthn',
[Sun Jun 14 11:11:54.453158 2020] [suexec:notice] [pid 4212] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Jun 14 11:11:54.717099 2020] [mpm_prefork:notice] [pid 4212] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.4.7 configured -- resuming normal operations
[Sun Jun 14 11:11:54.717133 2020] [core:notice] [pid 4212] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Jun 14 11:15:08.392445 2020] [mpm_prefork:notice] [pid 4212] AH00170: caught SIGWINCH, shutting down gracefully
[Sun Jun 14 11:15:09.481617 2020] [suexec:notice] [pid 4274] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Jun 14 11:15:09.548041 2020] [mpm_prefork:notice] [pid 4274] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.4.7 configured -- resuming normal operations
[Sun Jun 14 11:15:09.548070 2020] [core:notice] [pid 4274] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
