example
longer
example
here
Nextcloud version (eg, 20.0.5): Nextcloud desktop client 3.12.3
Nextcloud version (eg, 20.0.5): Nextcloud Hub 7 (28.0.4)
Operating system and version (eg, Ubuntu 20.04): macOS 14.4.1
Apache or nginx version (eg, Apache 2.4.25): Where do I find this?
PHP version (eg, 7.4): Version: 8.2.17
- Start nextcloud desktop client
- Wait for the client to check for changes on the server
- files start to sync and then I get “Encryption not ready: Default encryption module not loaded”
- I check setting on the server and it say the Default encryption module is enabled under the admin security settings.
- A fer serivces with use the webdev link now get 503 Errors as well.
Log page is blank everytime I look for logs on it.
'apps_paths' =>
0 =>
'path' => '/usr/local/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
1 =>
'path' => '/usr/local/www/nextcloud/apps-pkg',
'url' => '/apps-pkg',
'writable' => false,
'one-click-instance' => true,
'one-click-instance.user-limit' => 100,
'redis' =>
'host' => 'localhost',
'passwordsalt' => 'removed',
'secret' => 'removed',
0 => 'localhost',
1 => 'removed',
2 => 'removed',
3 => 'removed,
'datadirectory' => '/usr/local/www/nextcloud/data',
'version' => '28.0.4.1',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'removed',
'dbpassword' => 'removed',
'instanceid' => 'oceuo1dj8ha1',
'theme' => '',
'loglevel' => 2,
'twofactor_enforced' => 'true',
0 => 'admin',
0 => 'admin',
'mail_from_address' => 'alert',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'removed',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtphost' => 'removed',
'mail_smtpport' => 'removed',
'mail_smtpname' => 'removed',
'mail_smtppassword' => 'removed',
