Hello community,
two weeks ago i installed update 20.0.2.
I’m pretty sure that i did it in the manner described by the documentation.
Since then no cronjob ran (says the web interface), and connection to the database isn’t possible anymore (says the log in the web interface)
OS is Ubuntu 20.04 TLS.
Following syslog the cronjob is executed, e.g.:
Dec 14 00:05:01 nc-mcd CRON[1812]: (www-data) CMD (php -f /var/www/nextcloud/cron.php)
This is what the log in the web interface says:
|Error|cron|Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] Permission denied
- /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php - line 1449:OC\DB\Connection->connect()
- /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php - line 892:Doctrine\DBAL\Connection->getWrappedConnection()
- /var/www/nextcloud/lib/private/DB/Connection.php - line 202:Doctrine\DBAL\Connection->executeQuery()
- /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php - line 206:OC\DB\Connection->executeQuery()
- /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php - line 217:Doctrine\DBAL\Query\QueryBuilder->execute()
- /var/www/nextcloud/lib/private/AppConfig.php - line 345:OC\DB\QueryBuilder\QueryBuilder->execute()
- /var/www/nextcloud/lib/private/AppConfig.php - line 110:OC\AppConfig->loadConfigValues()
- /var/www/nextcloud/lib/private/AppConfig.php - line 301:OC\AppConfig->getApps()
- /var/www/nextcloud/lib/private/legacy/OC_App.php - line 949:OC\AppConfig->getValues()
- /var/www/nextcloud/lib/private/Server.php - line 668:OC_App::getAppVersions()
- /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 155:OC\Server->OC{closure}("*** sensiti … *")
- /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php - line 118:OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}("*** sensiti … *")
- /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 122:Pimple\Container->offsetGet()
- /var/www/nextcloud/lib/private/ServerContainer.php - line 156:OC\AppFramework\Utility\SimpleContainer->query()
- /var/www/nextcloud/lib/private/Server.php - line 1677:OC\ServerContainer->query()
- /var/www/nextcloud/lib/private/Server.php - line 1017:OC\Server->getMemCacheFactory()
- /var/www/nextcloud/lib/private/Server.php - line 1977:OC\ServerContainer->query()
- /var/www/nextcloud/lib/private/Files/View.php - line 118:OC\Server->getLockingProvider()
- /var/www/nextcloud/lib/private/Server.php - line 395:OC\Files\View->__construct()
- /var/www/nextcloud/lib/private/Server.php - line 1324:OC\ServerContainer->query()
- /var/www/nextcloud/lib/base.php - line 595:OC\Server->boot()
- /var/www/nextcloud/lib/base.php - line 1091:OC::init()
- /var/www/nextcloud/cron.php - line 42:require_once("/var/www/ne … p")|
Using the credentials in the config.php i can connect manually to the database.
I tried to upgrade to 20.0.3, but it throws a lot of errors:
root@nc-mcd:/var/www/nextcloud# sudo -u www-data php occ maintenance:mode --on
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] Permission denied in /var/www/nextcloud/lib/private/DB/Connection.php:72
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(1449): OC\DB\Connection->connect()
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(892): Doctrine\DBAL\Connection->getWrappedConnection()
#2 /var/www/nextcloud/lib/private/DB/Connection.php(202): Doctrine\DBAL\Connection->executeQuery()
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): OC\DB\Connection->executeQuery()
#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(217): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#7 /var/www/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#8 /var/www/nextcloud/lib/private/legacy/OC_App.php(949): OC\AppConfig->getValues()
#9 /var/www/nextcloud/lib/private/Server.php(668): OC_App::getAppVersions()
#10 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC{closure}()
#11 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}()
#12 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet()
#13 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query()
#14 /var/www/nextcloud/lib/private/Server.php(1677): OC\ServerContainer->query()
#15 /var/www/nextcloud/lib/private/Server.php(1017): OC\Server->getMemCacheFactory()
#16 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC{closure}()
#17 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}()
#18 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet()
#19 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query()
#20 /var/www/nextcloud/lib/private/Server.php(1977): OC\ServerContainer->query()
#21 /var/www/nextcloud/lib/private/Files/View.php(118): OC\Server->getLockingProvider()
#22 /var/www/nextcloud/lib/private/Server.php(395): OC\Files\View->__construct()
#23 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC{closure}()
#24 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}()
#25 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet()
#26 /var/www/nextcloud/lib/private/ServerContainer.php(156): OC\AppFramework\Utility\SimpleContainer->query()
#27 /var/www/nextcloud/lib/private/Server.php(1324): OC\ServerContainer->query()
#28 /var/www/nextcloud/lib/base.php(595): OC\Server->boot()
#29 /var/www/nextcloud/lib/base.php(1091): OC::init()
#30 /var/www/nextcloud/console.php(49): require_once(’/var/www/nextcl…’)
#31 /var/www/nextcloud/occ(11): require_once(’/var/www/nextcl…’)
#32 {main}root@nc-mcd:/var/www/nextcloud# history|less
Thankful for any help.
Bernd
