31.0.2.1
Debian 12
NGINX
- PHP version (e.g, 8.3):
8.2
Yes
After moving to a new host
Bare Metal
No
We have decided to move our Nextcloud to a new Server and move the database from a single MariaDB server into our MySQL 8 Cluster.
After the import of the SQL was finished (without errors or warnings) i completed the change in the config.php to the correct database settings.
Unfortunately we are receiving the following error:
An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused
- export mariadb nextcloud database
- import in a mysql 8 cluster
- fix the mysql credentials and host in the config.php
"reqId":"r62FMHttp4QpTvjyvu5M",
"level":3,
"time":"2025-04-04T15:00:23+02:00",
"remoteAddr":"10.1.200.1",
"user":false,
"app":"index",
"method":"GET",
"url":"/index.php/apps/files/preview-service-worker.js",
"message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused",
"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36",
"version":"31.0.2.1",
"exception":{
"Exception":"Doctrine\\DBAL\\Exception",
"Message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused",
"Code":2002,
"Trace":[
"file":"/var/www/share/next.[REDACTED]/htdocs/3rdparty/doctrine/dbal/src/Connection.php",
"line":458,
"function":"connect",
"class":"OC\\DB\\Connection",
"type":"->"
"line":416,
"function":"getDatabasePlatformVersion",
"class":"Doctrine\\DBAL\\Connection",
"type":"->"
"line":323,
"function":"detectDatabasePlatform",
"type":"->"
"file":"/var/www/share/next.[REDACTED]/htdocs/lib/private/DB/Connection.php",
"line":903,
"function":"getDatabasePlatform",
"type":"->"
"file":"/var/www/share/next.[REDACTED]/htdocs/lib/private/DB/ConnectionAdapter.php",
"line":235,
"function":"getDatabaseProvider",
"type":"->"
"file":"/var/www/share/next.[REDACTED]/htdocs/lib/private/DB/QueryBuilder/QueryBuilder.php",
"line":96,
"class":"OC\\DB\\ConnectionAdapter",
"type":"->"
"file":"/var/www/share/next.[REDACTED]/htdocs/lib/private/AppConfig.php",
"line":1226,
"function":"expr",
"class":"OC\\DB\\QueryBuilder\\QueryBuilder",
"type":"->"
"line":243,
"function":"loadConfig",
"class":"OC\\AppConfig",
"type":"->"
"line":1366,
"function":"searchValues",
"type":"->"
"file":"/var/www/share/next.[REDACTED]/htdocs/lib/private/App/AppManager.php",
"line":136,
"function":"getValues",
"type":"->"
"line":157,
"function":"getInstalledAppsValues",
"class":"OC\\App\\AppManager",
"type":"->"
"file":"/var/www/share/next.[REDACTED]/htdocs/lib/private/legacy/OC_App.php",
"line":188,
"function":"getInstalledApps",
"type":"->"
"file":"/var/www/share/next.[REDACTED]/htdocs/lib/private/AppFramework/Bootstrap/Coordinator.php",
"line":48,
"function":"getEnabledApps",
"class":"OC_App",
"type":"::"
"file":"/var/www/share/next.[REDACTED]/htdocs/lib/base.php",
"line":675,
"function":"runInitialRegistration",
"class":"OC\\AppFramework\\Bootstrap\\Coordinator",
"type":"->"
"line":1156,
"function":"init",
"class":"OC",
"type":"::"
"file":"/var/www/share/next.[REDACTED]/htdocs/index.php",
"line":22,
"args":["/var/www/share/next.[REDACTED]/htdocs/lib/base.php"],
"function":"require_once"
"File":"/var/www/share/next.[REDACTED]/htdocs/lib/private/DB/Connection.php",
"Line":237,
"exception":{},
"CustomMessage":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused"
2025/04/04 09:40:03 [error] 5357#5357: *151942 FastCGI sent in stderr: "PHP message: {"reqId":"vwJusrhNtqRvc6VKfR4K","level":3,"time":"2025-04-04T09:40:02+02:00","remoteAddr":"10.1.200.1","user":false,"app":"index","method":"GET","url":"/index.php/apps/files/preview-service-worker.js","message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user 'nextcloud'@'10.1.200.6' (using password: YES)","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36","version":"31.0.2.1","exception":{"Exception":"Doctrine\\DBAL\\Exception","Message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user 'nextcloud'@'10.1.200.6' (using password: YES)","Code":1045,"Trace":[{"file":"/var/www/share/next.[REDACTED]/htdocs/3rdparty/doctrine/dbal/src/Connection.php","line":458,"function":"connect","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/share/next.[REDACTED]/htdocs/3rdparty/d...; PHP message: {"reqId":"vwJusrhNtqRvc6VKfR4K","level":3,"time":"2025-04-04T09:40:03+02:00","remoteAddr":"10.1.200.1","user":false,"app":"core","method":"GET","url":"/index.php/apps/files/preview-service-worker.js","message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user 'nextcloud'@'10.1.200.6' (using password: YES)","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36","version":"31.0.2.1","exception":{"Exception":"Doctrine\\DBAL\\Exception","Message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user 'nextcloud'@'10.1.200.6' (using password: YES)","Code":1045,"Trace":[{"file":"/var/www/share/next.[REDACTED]/htdocs/3rdparty/doctrine/dbal/src/Connection.php","line":458,"function":"connect","class":"OC\\DB\\Connection","type":"->"},{"file":"/
'instanceid' => '[REDACTED]',
'passwordsalt' => '[REDACTED]+',
'secret' => '[REDACTED]',
0 => '[REDACTED]',
1 => '[REDACTED]',
2 => '[REDACTED]',
'datadirectory' => '/var/www/share/next.[REDACTED]/nx-data',
'version' => '31.0.2.1',
'overwrite.cli.url' => 'https://next.[REDACTED]',
'dbname' => 'nextcloud',
'dbhost' => '10.1.201.4',
'dbport' => '6033',
'dbuser' => 'nextcloud',
'dbpassword' => '[REDACTED]',
'ldapIgnoreNamingRules' => false,
'app_install_overwrite' =>
0 => 'files_fulltextsearch_tesseract',
1 => 'previewgenerator',
2 => 'documentserver_community',
3 => 'files_texteditor',
4 => 'twofactor_admin',
5 => 'integration_whiteboard',
6 => 'fulltextsearch',
7 => 'fulltextsearch_elasticsearch',
8 => 'files_fulltextsearch',
9 => 'impersonate',
10 => 'duplicatefinder',
11 => 'files_markdown',
12 => 'files_readmemd',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'dbindex' => 0,
'timeout' => 0.0,
'activity_expire_days' => 14,
'auth.bruteforce.protection.enabled' => true,
'blacklisted_files' =>
0 => '.htaccess',
1 => 'Thumbs.db',
2 => 'thumbs.db',
'cron_log' => true,
'enable_previews' => true,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\Movie',
6 => 'OC\\Preview\\PDF',
7 => 'OC\\Preview\\MP3',
8 => 'OC\\Preview\\TXT',
9 => 'OC\\Preview\\MarkDown',
10 => 'OC\\Preview\\Illustrator',
11 => 'OC\\Preview\\Photoshop',
12 => 'OC\\Preview\\TIFF',
13 => 'OC\\Preview\\SVG',
14 => 'OC\\Preview\\Movie',
15 => 'OC\\Preview\\MSOffice2007',
16 => 'OC\\Preview\\MSOffice',
'filesystem_check_changes' => 0,
'integrity.check.disabled' => false,
'knowledgebaseenabled' => false,
'logfile' => '/var/www/share/next.[REDACTED]/nextcloud.log',
'loglevel' => 0,
'log_rotate_size' => 104857600,
'preview_max_x' => 1024,
'preview_max_y' => 768,
'preview_max_scale_factor' => 1,
'quota_include_external_storage' => false,
'share_folder' => '/Shares',
'skeletondirectory' => '',
'theme' => '',
'trashbin_retention_obligation' => 'auto, 7',
'twofactor_enforced' => 'true',
0 => 'servicegruppe',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => 'notification',
'mail_domain' => '[REDACTED]',
'mail_smtpauth' => 1,
'mail_smtphost' => 'mail.[REDACTED]',
'mail_smtpport' => '587',
'mail_smtpname' => '[REDACTED]',
'mail_smtppassword' => '[REDACTED]',
cant run
Extended informations
- using a php test script to connect to the exact same host with user to access the database with the same password works
- using the mysql cli to connect to the cluster as the nextcloud user with the password copied from config to the nextcloud database works too
- the mysql cluster is loadbalanced with a proxysql server
