All works well except the part with the nextcoud.conf setting,
the machine that runs nextcloud is on IP 192.168.0.104 , on my router the port is forwarded
local ip with both tcp/udp to port 80
in my local network it all runs fine,just not on the outside
/etc/apache2/sites-available/nextcloud.conf
<virtualhost *:80="">
DocumentRoot "/var/www/nextcloud"
ServerName (what to fill in here) <----- my localhost , my 192.168.0.104, or my public ip ???
As ServerName you typically choose the domain name, this could be a local domain name such as nextcloud.local or if you use a ddns-service yoursubdomain.ddns-provider.com. So in theory you can now just put localhost and it should respond if you open nextcloud via the ip address.
What is strange that they don’t put this part in the SSL-vhost later:
Options +FollowSymlinks
AllowOverride All
<IfModule mod_dav.c>
Dav off
</IfModule>
Satisfy Any
</Directory>
Thanks for the reply,
but here is where i got stuck
i dont have domain names or dns providers
just my local network and a public ip
ServerName (what to fill in here) <----- my localhost eg 127.0.0.1 doesnt work , my 192.168.0.104 works but just local
Probably i overlook a tiny thing but i dont see it
so to be short if i set it to 192.168.0.104, all my pc’s phone and tab can connect but thats inside the house.
if i set it to localhost or 127.0.0.1 nothing works,
if i set it to my public ip example 88.154.154.123 it works but only local
Hi there!
I have the similar problem and I’m totally confused.
I have followed the installation on Linux instructions of Nextcloud document.
I use apache2, MariaDB and PHP v7.4 and have installed them successfully but now I don’t know how to run Nextcloud.
I don’t have a domain address and I’m using my IP.
How should I ensure that my nextcloud.conf and config.php have been set correctly?
You are answering to a thread that is five years old and already has been solved.
Short answer: You use the IP address as a ServerName in your Apache Virtual host and as a trusted domain in the config.php.
If you cannot get it working, please open a new thread, with more details about your setup like your Apache config, config.php and what you already have tried…
