After finishing the installation of Nextcloud AIO, it is not possible to access it.
    • Nextcloud AIO v12.5.0
    • Debian 13 Trixie
    • nginx 1.26.3
    • Yes
    • Immediately after installation
    • AIO
I am having a problem when trying to open Nextcloud AIO. After finishing the installation of the containers, when I click on the “Open your Nextcloud” button, it doesn’t open and a pop-up window appears saying: “Cannot open multiple instances. You can use AIO here by reloading the page.”
To try to fix it, I closed all Nextcloud instances, deleted the cookies, and tried to open Nextcloud in another browser in a private window, but I still can’t get in.
services:
    image: ghcr.io/nextcloud-releases/all-in-one:latest
    init: true
    restart: always
    volumes:
    network_mode: bridge
    ports:
      - 12:80
      - 1234:8080
      - 5678:8443
    environment:
      APACHE_PORT: 11000
      APACHE_IP_BINDING: 0.0.0.0
      SKIP_DOMAIN_VALIDATION: true
volumes:
server{
    listen 80;
    listen [::]:80;
    server_name mycloud.mynet;
    location / {
        return 301 https://$server_name$request_uri;
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    http2 on;
    ssl_certificate /etc/letsencrypt/live/mycloud.mynet/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/mycloud.mynet/privkey.pem;
    include /etc/letsencrypt/options-ssl-nginx.conf;
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
    location / {
        proxy_pass https://127.0.0.1:1234;
        proxy_set_header X-Forwarded-Port $server_port;
        proxy_set_header X-Forwarded-Scheme $scheme;
        proxy_set_header Host $host;
        proxy_set_header Early-Data $ssl_early_data;
        # Websocket
        proxy_http_version 1.1;
        proxy_set_header Connection "Upgrade";
  1. Running Docker Compose to install nextcloud-aio-mastercontainer
  2. URL configuration
  3. Installation of the containers
  4. Click on Open your Nextcloud
Trying to fix docker.sock permissions internally...
Creating docker group internally with id 989
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
[Thu Feb 05 10:50:34.613884 2026] [mpm_event:notice] [pid 145:tid 145] AH00489: Apache/2.4.66 (Unix) OpenSSL/3.5.4 configured -- resuming normal operations
[Thu Feb 05 10:50:34.613941 2026] [core:notice] [pid 145:tid 145] AH00094: Command line: 'httpd -D FOREGROUND'
[05-Feb-2026 10:50:34] NOTICE: fpm is running, pid 150
[05-Feb-2026 10:50:34] NOTICE: ready to handle connections
{"level":"info","ts":1770288634.6448805,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1770288634.6453717,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7369585459,"previous":9223372036854775807}
{"level":"info","ts":1770288634.645463,"msg":"using config from file","file":"/Caddyfile"}
{"level":"info","ts":1770288634.6470926,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1770288634.6522698,"msg":"serving initial configuration"}
NOTICE: PHP message: Skipping domain validation
Deleting duplicate sessions
NOTICE: PHP message: 404 Not Found
Type: Slim\Exception\HttpNotFoundException
Code: 404
Message: Not found.
File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
Line: 76
Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(62): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(53): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#12 /var/www/docker-aio/php/public/index.php(200): Slim\App->run()
#13 {main}
Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
nextcloud-aio-domaincheck
Total reclaimed space: 0B
There are no visible errors
There are no error logs
Don't know
Hi, can you follow all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub?
I was able to fix it! I had tried with the Nginx configuration found in “all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub” and had errors, but the problem was that I was doing it wrong. I tried again after your message and it worked.
Thank you very much.
