Administrator setting fail after hacker attack recovery
    • latest Spring 2026
    • rasbian OS
    • NGINX
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
My Joomla websites where under attack because of the JCE editor vunrability and I had to restore all my joomla websites several times. In order to to fix the attacks, I made an error on /var/www which influenced all of my websites, including my two nextcloud test sites. My Joomla sites are backup and the attack has stopped.
By my nextcloud websites both fail when I select Administrator settings: with;
Internal Server Error
The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
Technical details
  • Remote Address: 31.151.67.178
  • Request ID: gvs0ASrCmXkXDDy9Q98N
  • Type: OCP\Template\TemplateNotFoundException
  • Code: 0
  • Message: template file not found: template:admin
  • File: /var/www/nextcloud.platform1106.nl/html/lib/private/Template/TemplateFileLocator.php
  • Line: 39
Trace
#0 /var/www/nextcloud.platform1106.nl/html/lib/private/Template/Template.php(88): OC\Template\TemplateFileLocator->find()
#1 /var/www/nextcloud.platform1106.nl/html/lib/private/Template/Template.php(51): OC\Template\Template->findTemplate()
#2 /var/www/nextcloud.platform1106.nl/html/lib/private/Template/TemplateManager.php(37): OC\Template\Template->__construct()
#3 /var/www/nextcloud.platform1106.nl/html/lib/public/AppFramework/Http/TemplateResponse.php(190): OC\Template\TemplateManager->getTemplate()
#4 /var/www/nextcloud.platform1106.nl/html/apps/settings/lib/Controller/CommonSettingsTrait.php(124): OCP\AppFramework\Http\TemplateResponse->render()
#5 /var/www/nextcloud.platform1106.nl/html/apps/settings/lib/Controller/CommonSettingsTrait.php(178): OCA\Settings\Controller\AdminSettingsController->formatSettings()
#6 /var/www/nextcloud.platform1106.nl/html/apps/settings/lib/Controller/AdminSettingsController.php(56): OCA\Settings\Controller\AdminSettingsController->getIndexResponse()
#7 /var/www/nextcloud.platform1106.nl/html/lib/private/AppFramework/Http/Dispatcher.php(165): OCA\Settings\Controller\AdminSettingsController->index()
#8 /var/www/nextcloud.platform1106.nl/html/lib/private/AppFramework/Http/Dispatcher.php(78): OC\AppFramework\Http\Dispatcher->executeController()
#9 /var/www/nextcloud.platform1106.nl/html/lib/private/AppFramework/App.php(137): OC\AppFramework\Http\Dispatcher->dispatch()
#10 /var/www/nextcloud.platform1106.nl/html/lib/private/Route/Router.php(324): OC\AppFramework\App::main()
#11 /var/www/nextcloud.platform1106.nl/html/lib/base.php(1159): OC\Route\Router->match()
#12 /var/www/nextcloud.platform1106.nl/html/index.php(25): OC::handleRequest()
#13 {main}
I reinstalled NEXTcloud on another website and of course that one is working just fine.
I compared all index.php settings and *.js setting and even reapplied directory permission to 750 en files to 640. But nothing seems to help.
NGINX error log is not filled and nextcloud.log does not show any clue.
Who know what to do next, besides starting over! Or export and import to the new site.
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
I did a "sudo diff -qr /var/www/nextcloud.a/html /var/www/nextcloud.b/html and found the admin.php was missing from the old sites. with a sudo “diff -qr /var/www/nextcloud.a/html /var/www/nextcloud.b.eu/html | grep admin.php | grep admin.php” I found all missing and copied them over.
I rememdered that the attacker uploaded a admin.php to my websites and I removed them, making the error doing that in /var/www and not in each site seperate.
All is fine now, also nextcloud. That $^#^# attack has cost me two weeks of trying and hardening my sites.
Regards.
Glad you solved it.
Prove your backup/restore strategy.
