Admin Settings for Suspicious login
  • Nextcloud
    • AIO 31.0.6
    • Ubuntu LTS
    • YES
    -After Update Hub9 to Hub10
    -AIO (Docker)
Admin Settings for Suspicious login disapeard in the UI. Once the update to Hub10 was pushed on AIO, the section in the settings dissapeared. I would like to ask if this is intentional, or a bug.
Kind regards
Based on the changelog, the training data graph was dropped from the UI to ease development. The statistics themselves are still available via the API for exporting for analysis / sending to Grafana, etc.
Hi jtr
Thank you, sorry i didn spot this, that gives an explanation. I noticed yesterday that i see in the protocolle that a suspicious login was detected. Is there a way that this sends a notification?
Kind regards
